[postgis-users] Postgis Update from 2.4 to 3.0
Sandro Santilli
strk at kbt.io
Thu May 28 00:58:27 PDT 2020
On Tue, May 26, 2020 at 08:23:24AM +0000, Zwettler Markus (OIZ) wrote:
> Hi,
> We used and had postgis24 installed:
> postgis24_96-client-2.4.8-5.rhel7.x86_64
> postgis24_96-2.4.8-5.rhel7.x86_64
> pgrouting_96-2.6.2-1.rhel7.x86_64
> ogr_fdw96-1.0.8-1.rhel7.x86_64
> After an Linux update postgis30 packages were installed:
> postgis30_96-client-3.0.1-5.rhel7.x86_64
> postgis30_96-3.0.1-5.rhel7.x86_64
> pgrouting_96-3.0.0-rc1_2.rhel7.x86_64
> ogr_fdw96-1.0.9-1.rhel7.x86_64
> Afaik, we must do an "alter extension postgis update" now.
> QUESTION: Is an update to postgis30 that easy? Could there be any problems?
>From 2.4 to 3.0 you will ALSO want to re-package the RASTER
extension, which would be "unpakcaged" by the call:
ALTER EXTENSION postgis UPDATE
A WARNING message from the above command should tell you how
to cleanly complete the upgrade, which will be running:
SELECT postgis_extensions_upgrade();
--strk;
