[postgis-users] Postgis and ArcGIS Data Store
Marco Boeringa
marco at boeringa.demon.nl
Thu Nov 5 10:16:02 PST 2020
I think the only thing you need to do is to make sure the second
instance does not use one of the reserved port numbers that ArcGIS Data
Store uses
(https://enterprise.arcgis.com/en/data-store/latest/install/windows/ports-used-by-arcgis-data-store.htm).
That way, the instances are likely totally independent and should not
interfere, even when running on the same server, assuming ArcGIS Data
Store uses its own installation folders etc.
By default, PostgreSQL uses port 5432, and this is easily changeable via
the "postgresql.conf" config file. Based on the link to the reserved
post numbers of ArcGIS Data Store, it appears there is no conflict, so
you likely are OK running them together.
Marco
Op 5-11-2020 om 16:59 schreef Mark Volz:
> Hello,
> Can postgis/postgres run along with ArcGIS Datastore which I
> understand also uses postgres? If possible I would want two separate
> instances so that ArcGIS does not mess with the data in postgis/postgres.
> Thanks!
> Sincerely,
> *Mark Volz, GISP***
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201105/3bae4939/attachment.html>
