[postgis-users] Topology creation performance
Alexandre Silva
amsilva at infoportugal.impresa.pt
Fri Nov 20 08:55:06 PST 2020
Hello,
I'm creating a topology with a large amount of lines (around 165k) and when adding those lines to the topology, the number of iterations per second drops considerably as more lines are added. The lines are added one at a time in a transaction and the topology has 0 tolerance.
When adding the lines with the toTopogeom method, using a geohash ordering (st_geohash(st_transform(st_pointn(st_exteriorring(st_envelope(geom)), 1), 4326))) it takes around 4h to complete.
Our use case of the topology depends on a certain order of the added lines (some fixing logic will be added in a later stage) and using that ordering the process was stopped at 78% after a 50h wait (by that time each line was taking about 15s).
The slower ordering method results in the whole area being added to the topology in a layered style (rivers, roads, rural areas, etc.) and after the first one, there are already some faces with a large area, and the performance starts dropping rapidly. My suspicion is that this faces are the culprit of this slowing down.
In a first attempt to fix it I tried deleting the faces after each line was added, and it improved a little at the start but by the second half it's not much of a difference.
In another attempt, I used the AddEdge method, and it processed all the lines in about 15 minutes. Even though this needs the polygonize method to be run afterwards, from what I could discover it seems that every edge is only processed once, instead of multiple times. (In a older post (https://postgis-users.postgis.refractions.narkive.com/Xg3wV8V2/postgis-topology-performance) this approach seems to be the way to go). The major disadvantage of this method is that every line needs to be split beforehand, so the AddEdge doesn't throw an error, but using any other of the existing methods (toTopogeom and TopoGeo_AddLineString) it doesn't seems to be a way to get the performance that I get with AddEdge.
Are my assumptions are correct? And is the AddEdge the way to go or is there another way?
Thanks,
Alexandre Silva
[http://newsletter.impresapublishing.pt/i/barra_ip.jpg]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201120/9205d370/attachment.html>
