[postgis-users] using postgis for bathymetry data
Regina Obe
lr at pcorp.us
Fri Nov 20 09:01:08 PST 2020
How far off do they differ? Could be an issue of units I suppose.
If you can give an example of one in ArcGIS vs. PostGIS that would help a
bit.
If you can also provide a sample to data you are working with that would
help and your resulting query in PostGIS.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Amy O'Keefe
Sent: Friday, November 20, 2020 11:49 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] using postgis for bathymetry data
I have xyz bathymetry data from a port which I'm trying to calculate the
volume of regions for. My results in ArcGIS always seem to differ from that
in PostGIS - I have no idea which is more accurate or how each calculates
its final result. I've loaded the exact same raster into postgis and use the
intersect query to extract the required polygon of interest, before
extruding it and then taking the volume. I'm quite new at this, so I'm
afraid I'm going the wrong way about it
This email and any attachments are confidential and intended solely for the
use of the addressee and may contain information which is covered by legal,
professional or other privilege. If you have received this email in error
please notify the system manager at postmaster at ulster.ac.uk
<mailto:postmaster at ulster.ac.uk> and delete this email immediately. Any
views or opinions expressed are solely those of the author and do not
necessarily represent those of Ulster University.
The University's computer systems may be monitored and communications
carried out on them may be recorded to secure the effective operation of the
system and for other lawful purposes. Ulster University does not guarantee
that this email or any attachments are free from viruses or 100% secure.
Unless expressly stated in the body of a separate attachment, the text of
email is not intended to form a binding contract. Correspondence to and from
the University may be subject to requests for disclosure by 3rd parties
under relevant legislation.
The Ulster University was founded by Royal Charter in 1984 and is registered
with company number RC000726 and VAT registered number GB672390524.The
primary contact address for Ulster University in Northern Ireland is Cromore
Road, Coleraine, Co. Londonderry BT52 1SA
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201120/9a88badb/attachment.html>
