[postgis-users] Can't install PostGIS into PostgreSQL 13
Regina Obe lr at pcorp.us
Wed Oct 14 05:33:20 PDT 2020
Hey all sorry I’m still in the middle of my packaging, a bit behind schedule.  I hope to be done this weekend – taking a bit extra time since I’m building with newer GDAL and Proj.
If you are in a rush, the binaries for PG13 are here
https://winnie.postgis.net/download/windows/pg13/buildbot/
1)      PostGIS: https://winnie.postgis.net/download/windows/pg13/buildbot/postgis-pg13-binaries-3.0.2w64gcc81.zip  (make sure not to overwrite any files you already have installed, but you can copy in same named folders of your install)
2)      Ogr_fdw - https://winnie.postgis.net/download/windows/pg13/buildbot/extras/ogrfdw-pg13-binaries-masterw64gcc81.zip
3)      pgRouting 3.1.0 will be there shortly -
I haven’t had a chance to stress test – so if you are up for it and find issues before my packaging is complete, that would be great.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Calle Hedberg
Sent: Wednesday, October 14, 2020 7:18 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Can't install PostGIS into PostgreSQL 13
Just like Chia-Yun, I've found that
- the stack builder with pg 13 does not include postgis
- the osgeo http://download.osgeo.org/postgis/windows/ site does not have a pg 13 version
So the question is, for those of us who MUST have postgis with pg: do we have to wait for a new pg13-compatible postgis build for Windows, or can we use the one released for pg 12, somehow? Since Chia-Yun indicates there's a problem with that when installed as is - are there any workarounds that will make it work?
Regards
Calle
On Wed, 14 Oct 2020 at 11:50, 張家芸 <grace3045 at gmail.com <mailto:grace3045 at gmail.com> > wrote:
Hi Marco,
Thank you for your reply. I sent EDB an email 2 days ago but no response, so I was trying to find other ways to fix my problem.
I tried to install PostGIS inside PostgreSQL by CREATE EXTENSION postgis;
But the error message shows that I don't have postgis.control file.
I also saw an old solution for Ubuntu is to run the command:
 $ sudo apt-get install postgis postgresql-9.5-postgis-scripts
But I am using Windows, not sure how to transform the command.
Chia-Yun
On Wed, Oct 14, 2020 at 11:06 AM Marco Boeringa <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Hi Chia-Yun,
I hadn't heard of Stack Builder yet, but I see it is an utility of EnterpriseDB for Windows (https://www.enterprisedb.com/edb-docs/d/postgresql/installation-getting-started/installation-guide/13.0/using_stackbuilder.html), so I think you should ask them:
https://support.enterprisedb.com/support/s/
PostGIS certainly is supported with PostgreSQL 13. I run it on Ubuntu 20.04, and the package manager there installs PostgreSQL 13 including PostGIS without issues.
Marco
Op 14-10-2020 om 10:49 schreef 張家芸:
I installed PostgreSQL 13, but can't find either spatial extension folder or PostGIS in the Stack Builder 4.2. Then I downloaded PostGIS bundle (postgis-bundle-pg12x64-setup-3.0.2-1.exe) but the installation procedure always interrupted by this message:
PostGIS has to be installed to the PostgreSQL folder
No matter if I install at default destination or my PostgreSQL folder.
Is this because PostGIS haven't fully upgraded to fit PostgreSQL 13? What should I do, install PostgreSQL 12 instead?
Thank you
Chia-Yun
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
Carl-Anders (Calle) Hedberg
HISP
Researcher & Technical Specialist
Health Information Systems Programme – South Africa
Cell:        +47 41461011 (Norway)
Iridium SatPhone: +8816-315-19119 (usually OFF)
E-mail1: calle at hisp.org <mailto:calle at hisp.org>
E-mail2: calle.hedberg at gmail.com <mailto:calle.hedberg at gmail.com>
Skype:  calle_hedberg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201014/77ba486d/attachment.html>
