[postgis-users] Can't install PostGIS into PostgreSQL 13
Calle Hedberg
calle.hedberg at gmail.com
Wed Oct 14 04:18:14 PDT 2020
Just like Chia-Yun, I've found that
- the stack builder with pg 13 does not include postgis
- the osgeo http://download.osgeo.org/postgis/windows/ site does not have a
pg 13 version
So the question is, for those of us who MUST have postgis with pg: do we
have to wait for a new pg13-compatible postgis build for Windows, or can we
use the one released for pg 12, somehow? Since Chia-Yun indicates there's a
problem with that when installed as is - are there any workarounds that
will make it work?
Regards
Calle
On Wed, 14 Oct 2020 at 11:50, 張家芸 <grace3045 at gmail.com> wrote:
> Hi Marco,
> Thank you for your reply. I sent EDB an email 2 days ago but no response,
> so I was trying to find other ways to fix my problem.
> I tried to install PostGIS inside PostgreSQL by CREATE EXTENSION postgis;
> But the error message shows that I don't have postgis.control file.
> I also saw an old solution for Ubuntu is to run the command:
> $ sudo apt-get install postgis postgresql-9.5-postgis-scripts
> But I am using Windows, not sure how to transform the command.
> Chia-Yun
> On Wed, Oct 14, 2020 at 11:06 AM Marco Boeringa <marco at boeringa.demon.nl>
> wrote:
>> Hi Chia-Yun,
>> I hadn't heard of Stack Builder yet, but I see it is an utility of
>> EnterpriseDB for Windows (
>> https://www.enterprisedb.com/edb-docs/d/postgresql/installation-getting-started/installation-guide/13.0/using_stackbuilder.html),
>> so I think you should ask them:
>> https://support.enterprisedb.com/support/s/
>> PostGIS certainly is supported with PostgreSQL 13. I run it on Ubuntu
>> 20.04, and the package manager there installs PostgreSQL 13 including
>> PostGIS without issues.
>> Marco
>> Op 14-10-2020 om 10:49 schreef 張家芸:
>> I installed PostgreSQL 13, but can't find either spatial extension folder
>> or PostGIS in the Stack Builder 4.2. Then I downloaded PostGIS bundle
>> (postgis-bundle-pg12x64-setup-3.0.2-1.exe) but the installation procedure
>> always interrupted by this message:
>> PostGIS has to be installed to the PostgreSQL folder
>> No matter if I install at default destination or my PostgreSQL folder.
>> Is this because PostGIS haven't fully upgraded to fit PostgreSQL 13? What
>> should I do, install PostgreSQL 12 instead?
>> Thank you
>> Chia-Yun
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
*Carl-Anders (Calle) Hedberg*
HISP
Researcher & Technical Specialist
Health Information Systems Programme – South Africa
Cell: +47 41461011 (Norway)
Iridium SatPhone: +8816-315-19119 (usually OFF)
E-mail1: calle at hisp.org
E-mail2: calle.hedberg at gmail.com
Skype: calle_hedberg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201014/08fa4a35/attachment.html>
