[postgis-users] Can't install PostGIS into PostgreSQL 13
張家芸
grace3045 at gmail.com
Wed Oct 14 02:50:17 PDT 2020
Hi Marco,
Thank you for your reply. I sent EDB an email 2 days ago but no response,
so I was trying to find other ways to fix my problem.
I tried to install PostGIS inside PostgreSQL by CREATE EXTENSION postgis;
But the error message shows that I don't have postgis.control file.
I also saw an old solution for Ubuntu is to run the command:
$ sudo apt-get install postgis postgresql-9.5-postgis-scripts
But I am using Windows, not sure how to transform the command.
Chia-Yun
On Wed, Oct 14, 2020 at 11:06 AM Marco Boeringa <marco at boeringa.demon.nl>
wrote:
> Hi Chia-Yun,
> I hadn't heard of Stack Builder yet, but I see it is an utility of
> EnterpriseDB for Windows (
> https://www.enterprisedb.com/edb-docs/d/postgresql/installation-getting-started/installation-guide/13.0/using_stackbuilder.html),
> so I think you should ask them:
> https://support.enterprisedb.com/support/s/
> PostGIS certainly is supported with PostgreSQL 13. I run it on Ubuntu
> 20.04, and the package manager there installs PostgreSQL 13 including
> PostGIS without issues.
> Marco
> Op 14-10-2020 om 10:49 schreef 張家芸:
> I installed PostgreSQL 13, but can't find either spatial extension folder
> or PostGIS in the Stack Builder 4.2. Then I downloaded PostGIS bundle
> (postgis-bundle-pg12x64-setup-3.0.2-1.exe) but the installation procedure
> always interrupted by this message:
> PostGIS has to be installed to the PostgreSQL folder
> No matter if I install at default destination or my PostgreSQL folder.
> Is this because PostGIS haven't fully upgraded to fit PostgreSQL 13? What
> should I do, install PostgreSQL 12 instead?
> Thank you
> Chia-Yun
> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201014/acd25a39/attachment.html>
