[postgis-users] Can't install PostGIS into PostgreSQL 13
Marco Boeringa marco at boeringa.demon.nl
Wed Oct 14 02:06:24 PDT 2020
Hi Chia-Yun,
I hadn't heard of Stack Builder yet, but I see it is an utility of
EnterpriseDB for Windows
(https://www.enterprisedb.com/edb-docs/d/postgresql/installation-getting-started/installation-guide/13.0/using_stackbuilder.html),
so I think you should ask them:
https://support.enterprisedb.com/support/s/
PostGIS certainly is supported with PostgreSQL 13. I run it on Ubuntu
20.04, and the package manager there installs PostgreSQL 13 including
PostGIS without issues.
Marco
Op 14-10-2020 om 10:49 schreef 張家芸:
> I installed PostgreSQL 13, but can't find either spatial
> extension folder or PostGIS in the Stack Builder 4.2. Then I
> downloaded PostGIS bundle (postgis-bundle-pg12x64-setup-3.0.2-1.exe)
> but the installation procedure always interrupted by this message:
> PostGIS has to be installed to the PostgreSQL folder
> No matter if I install at default destination or my PostgreSQL folder.
> Is this because PostGIS haven't fully upgraded to fit PostgreSQL 13?
> What should I do, install PostgreSQL 12 instead?
> Thank you
> Chia-Yun
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201014/173ec041/attachment.html>
