[postgis-users] Enabling NetCDF export in PostGIS
Mario A. Tarouco De Sales mts at dhigroup.com
Tue Sep 15 02:18:50 PDT 2020
Hello
I need to export rasters in PostGIS to NetCDF format using ST_AsGDALRaster .
I searched a lot for this topic but not much information is available. And the available information is confusing...
In https://trac.osgeo.org/gdal/wiki/NetCDF it's mentioned "GDAL 1.9 includes support for NetCDF-4 file format (provided that nc-config is found in the configure stage), as well as the 64-bit offset file format. HDF4 and HDF5 files are also supported, although the respective driver is used if available. The syntax "NETCDF:<file>" forces the use of the NetCDF driver."
GDAL version in my PostGIS is 2.2 so this should be possible,
I have installed netcdf and added it to the path but now I'm stuck. Where to place the nc-config file? What is the 64-bit offset file format?
Any help is highly appreciated
Best regards
Mario
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200915/2aa7d29b/attachment.html>
