[postgis-users] Bytea data type and its application and uses
Giuseppe Broccolo
g.broccolo.7 at gmail.com
Fri Sep 18 08:00:23 PDT 2020
Hi Shao,
I don't know how PowerBI works frankly. My idea is that they do not support
direct access to bytea data, so maybe you need to put something in the
middle to decode/encode.
Giuseppe.
Il giorno ven 18 set 2020 alle ore 11:17 Shaozhong SHI <
shishaozhong at gmail.com> ha scritto:
> Hi, Giuseppe,
> Thank you for your reply.
> We know those literature. The issue is that there is a lack of working
> examples to demonstrate its use.
> Let's say that people are using PowerBI, Graphic Packages, GIS application
> users and etc. Can these packages access and retrieve image data (Bytea)
> from PostGIS?
> Regards,
> Shao
> On Fri, 18 Sep 2020 at 11:07, Giuseppe Broccolo <g.broccolo.7 at gmail.com>
> wrote:
>> Hi Shao,
>> What do you need to store, more specifically? Since this is a PostGIS
>> related thread, is it about raster data, etc.?
>> Anyway, as a general info about binary data: there are two general ways
>> to insert binaries into a PostgreSQL database, the hex format and the
>> escape format. I attach here the reference:
>> https://www.postgresql.org/docs/12/datatype-binary.html
>> As a personal experience, I used the hexadecimal format: the idea is to
>> convert the binary blob into hex digits representation, where one digit
>> represents an hex nibble, and each byte of the binary blob is converted
>> into two digits, with the most significant nibble first. Then the hex
>> digits can be inserted as you would insert a string, preceded with the
>> char \x.
>> Depending on what you use at the application side, there are different
>> ways of encoding a binary blob into hex format. If you want to try
>> something "manually" from a file using psql, try with utilities like
>> hexdump, keeping in mind that the binary content in the file is encoded
>> using the platform's endianness, i.e. with the most significant nibble put
>> for first or for last (check this from your OS).
>> Hope it helped,
>> Giuseppe.
>> Il giorno gio 17 set 2020 alle ore 20:58 Shaozhong SHI <
>>> We can see various publications on the Bytea data type.
>>> However, it is difficult to find practical examples of how to use it.
>>> Anyone knows?
>>> Regards,
>>> Shao
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200918/59713958/attachment.html>
