[postgis-users] intersect two tables one row at a time
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Sat Sep 19 14:38:37 PDT 2020
On 9/19/2020 5:03 PM, karsten wrote:
> Hi all,
> I have two polygon geometry tables say A and B and trying to find the
> ids from Table B
> where their geometries intersect for each individual record in table
> A. I have tried many things that did not work
> and this was my starting point query:
> Select array_agg(B.id) from A ,B where ST_Intersects(A.geom,B.geom) ;
Try:
Select A.id, Array_agg(B.id( from A, B where
ST_Intersects(A.geom,B.geom) group by A.id order by A.id;
> I was expecting to get only the ids of table B that intersect the
> geometry of one row, but what this query returns seems
> to be a string of all ids the there entire two layers intersect. I
> don't understand why that is.
> How can I restrict the query above further so that I get back only the
> ids for each row (one geometry of table A  at a time with the ids of
> intersecting polygons from table B)
> Cheers
> Karsten
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
