[postgis-users] intersect two tables one row at a time
karsten karsten at terragis.net
Sat Sep 19 14:49:36 PDT 2020
Yes that works
thanks !
Would anyone  have an explanation why the initial query below seems to
intersect the entire two layers and not
each records of table A with geometries of table B ?
Cheers
Karsten
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Stephen Woodbridge
Sent: Saturday, September 19, 2020 14:39
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] intersect two tables one row at a time
On 9/19/2020 5:03 PM, karsten wrote:
> Hi all,
> I have two polygon geometry tables say A and B and trying to find the
> ids from Table B where their geometries intersect for each individual
> record in table A. I have tried many things that did not work and this
> was my starting point query:
> Select array_agg(B.id) from A ,B where ST_Intersects(A.geom,B.geom) ;
Try:
Select A.id, Array_agg(B.id( from A, B where
ST_Intersects(A.geom,B.geom) group by A.id order by A.id;
> I was expecting to get only the ids of table B that intersect the
> geometry of one row, but what this query returns seems to be a string
> of all ids the there entire two layers intersect. I don't understand
> why that is.
> How can I restrict the query above further so that I get back only the
> ids for each row (one geometry of table A  at a time with the ids of
> intersecting polygons from table B) Cheers Karsten
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
