[postgis-users] Setting multiple columns in one UPDATE request
Regina Obe lr at pcorp.us
Sun Sep 27 18:26:15 PDT 2020
I prefer doing it in the FROM and not bothering using a CTE.
So something like
UPDATE <MY_TABLE> SET area = f.area, area_perimeter = f.area/f.perimeter
FROM (SELECT id, ST_Area(<GEOMETRY_COLUMN>) AS area, ST_Perimeter(<GEOMETRY COLUMN>) AS perimeter
        FROM <MY TABLE> ) AS f
WHERE f.id = <MY TABLE>.id;
Note the FROM does not need to be the same as your table, you just need to have a common join.  That makes it particularly handy for updating with aggregate values
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Marco Boeringa
Sent: Sunday, September 27, 2020 1:18 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Setting multiple columns in one UPDATE request
Thanks for pointing that out Alexander. I was just about to start a test after some code modifications, but now realized based on the example you pointed out that I was missing the "FROM cte" clause in my SQL statement. It feels a bit unnatural to have to specify that one, as you already define the cte name after the WITH keyword. But this example sorted it out.
Curious to see how it runs and if it leads to a measurable performance enhancement.
Marco
Op 27-9-2020 om 18:30 schreef Alexander Gataric:
You have the correct link. Here's an example.
https://stackoverflow.com/questions/36908495/update-with-result-from-cte-postgresql
Get BlueMail for Android <http://www.bluemail.me/r?b=16117>
On Sep 27, 2020, at 7:47 AM, Marco Boeringa <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Hi Alexander,
I guess I could use the optional WITH clause that is part of UPDATE in PostgreSQL?:
https://www.postgresql.org/docs/12/sql-update.html
It would have been nice to see an example of such usage in the PostgreSQL help, but I'll figure it out.
Marco
Op 27-9-2020 om 13:59 schreef Alexander Gataric:
Rewrite to have a CTE with the area calculations and join to the table.
On Sep 27, 2020, at 2:29 AM, Marco Boeringa <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Hi all,
This may be an irrelevant basic question, but I just cannot find a clear
answer to this, there is no documentation in the PostgreSQL docs for
UPDATE about this:
In case I set multiple columns using some PostGIS function that clearly
has a (considerable) cost associated with it, and the value of the first
column being set is also needed to set the second column, does
PostgreSQL automatically optimize this and re-use the value already
calculated for column 1 to set column 2's value, or is each column's SET
statement treated as independent entity?
E.g. let's say I want to calculate both area, and the division of area
and perimeter, like:
UPDATE <MY_TABLE> SET area = ST_Area(<GEOMETRY_COLUMN>), area_perimeter
= ST_Area(<GEOMETRY_COLUMN>) / ST_Perimeter(<GEOMETRY_COLUMN>)
Will PostgreSQL only process 'ST_Area(<GEOMETRY_COLUMN>)' once in this
case, thus saving CPU load, or do I need to rewrite the SQL statement
somehow to achieve that?
Marco
  _____
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
  _____
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200927/03d83c81/attachment.html>
