[postgis-users] Setting multiple columns in one UPDATE request
Marco Boeringa marco at boeringa.demon.nl
Mon Sep 28 00:36:44 PDT 2020
Regina,
Thanks for your suggestion.
How is this performance wise? Is not using a CTE as in your suggestion,
supposedly faster than with using a CTE, or is this just a syntax thing
and performance is expected to be equal?
It would still be nice though, if PostgreSQL somehow handled this
automatically, and one could use the most basic form yet be sure it was
optimized. It also reads more easily to just see:
UPDATE <MY_TABLE> SET area = ST_Area(<GEOMETRY_COLUMN>), area_perimeter
= ST_Area(<GEOMETRY_COLUMN>) / ST_Perimeter(<GEOMETRY_COLUMN>)
in your code, instead of more elaborate construct involving a join.
Marco
Op 28-9-2020 om 03:26 schreef Regina Obe:
> I prefer doing it in the FROM and not bothering using a CTE.
> So something like
> UPDATE <MY_TABLE> SET area = f.area, area_perimeter = f.area/f.perimeter
> FROM (SELECT id, ST_Area(<GEOMETRY_COLUMN>) AS area, ST_Perimeter(<GEOMETRY COLUMN>) AS perimeter
>          FROM <MY TABLE> ) AS f
> WHERE f.id = <MY TABLE>.id;
> Note the FROM does not need to be the same as your table, you just
> need to have a common join.  That makes it particularly handy for
> updating with aggregate values
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Marco Boeringa
> *Sent:* Sunday, September 27, 2020 1:18 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] Setting multiple columns in one UPDATE
> request
> Thanks for pointing that out Alexander. I was just about to start a
> test after some code modifications, but now realized based on the
> example you pointed out that I was missing the "FROM cte" clause in my
> SQL statement. It feels a bit unnatural to have to specify that one,
> as you already define the cte name after the WITH keyword. But this
> example sorted it out.
> Curious to see how it runs and if it leads to a measurable performance
> enhancement.
> Marco
> Op 27-9-2020 om 18:30 schreef Alexander Gataric:
>     You have the correct link. Here's an example.
>     https://stackoverflow.com/questions/36908495/update-with-result-from-cte-postgresql
>     Get BlueMail for Android <http://www.bluemail.me/r?b=16117>
>     On Sep 27, 2020, at 7:47 AM, Marco Boeringa
>     <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl>> wrote:
>         Hi Alexander,
>         I guess I could use the optional WITH clause that is part of
>         UPDATE in PostgreSQL?:
>         https://www.postgresql.org/docs/12/sql-update.html
>         It would have been nice to see an example of such usage in the
>         PostgreSQL help, but I'll figure it out.
>         Marco
>         Op 27-9-2020 om 13:59 schreef Alexander Gataric:
>             Rewrite to have a CTE with the area calculations and join
>             to the table.
>             On Sep 27, 2020, at 2:29 AM, Marco Boeringa
>             wrote:
>                 Hi all,
>                 This may be an irrelevant basic question, but I just cannot find a clear
>                 answer to this, there is no documentation in the PostgreSQL docs for
>                 UPDATE about this:
>                 In case I set multiple columns using some PostGIS function that clearly
>                 has a (considerable) cost associated with it, and the value of the first
>                 column being set is also needed to set the second column, does
>                 PostgreSQL automatically optimize this and re-use the value already
>                 calculated for column 1 to set column 2's value, or is each column's SET
>                 statement treated as independent entity?
>                 E.g. let's say I want to calculate both area, and the division of area
>                 and perimeter, like:
>                 Will PostgreSQL only process 'ST_Area(<GEOMETRY_COLUMN>)' once in this
>                 case, thus saving CPU load, or do I need to rewrite the SQL statement
>                 somehow to achieve that?
>                 Marco
>                 postgis-users mailing list
>                 postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>                 https://lists.osgeo.org/mailman/listinfo/postgis-users
>             _______________________________________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200928/675f625b/attachment.html>
