[postgis-users] Solar azimuth calculator
Alexander Gataric
gataric at usa.net
Thu Apr 15 07:53:16 PDT 2021
Does anyone have the SQL for PostGIS to calculate the solar azimuth and elevation for a time and point?
Thanks
Get BlueMail for Android
On Apr 12, 2021, 8:38 AM, at 8:38 AM, "Palacios García Cuevas, Elena" <epgcuevas at indra.es> wrote:
>Thank you Martin. With ST_ReducePrecision I got the expected result.
>The polygon, although is a complex one, is valid. I will file a ticket
>with a sample for the ST_Union issue.
>________________________________
>De: postgis-users <postgis-users-bounces at lists.osgeo.org> en nombre de
>Martin Davis <mtnclimb at gmail.com>
>Enviado: martes, 6 de abril de 2021 20:46
>Para: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>Asunto: Re: [postgis-users] Reduce precision using ST_union with
>gridSize
>The issue with ST_Union not working with an empty polygon certainly
>sounds like a bug, and we should look into that. If you can file a
>ticket that would be great. (It would be helpful to have the polygon
>data which is causing the problem. Is it valid?)
>In any case now there is the function ST_ReducePrecision [1] which is
>specifically designed to do what you want. (It uses most of the same
>machinery as ST_Union, but should avoid whatever the issue with
>ST_Union is).
>[1] https://postgis.net/docs/manual-3.1/ST_ReducePrecision.html
>On Tue, Apr 6, 2021 at 7:28 AM Palacios García Cuevas, Elena
><epgcuevas at indra.es<mailto:epgcuevas at indra.es>> wrote:
>Hello,
>I am trying to simplify a polygon by reducing the precision using
>ST_Union with the gridSize parameter ( I am using postgis 3.1 and
>GEOS 3.9.1). I have read that it is possible to do that by a union of a
>geometry with an empty geometry
>(http://blog.cleverelephant.ca/2020/12/waiting-postgis-31-3.html).
>However, does not works for me ( maybe is my fault because I am new
>with postgis). I have tried as follows:
>CREATE TABLE public.error_union_empty
> geom geometry(MultiPolygon),
> gid integer NOT NULL DEFAULT nextval('fallo_gid_seq'::regclass),
> CONSTRAINT error_union_empty_pkey PRIMARY KEY (gid)
>INSERT INTO error_union_empty
>(SELECT ST_union(geom,ST_GeomFromText('POLYGON EMPTY'), 0.001152) geom
>FROM f_polygon);
>But the result is an empty table.
>Then I tried to do the same but by doing the union with the polygon
>himself, and this approach seems to work ok.
>CREATE TABLE public.error_union_empty2
> CONSTRAINT error_union_empty2_pkey PRIMARY KEY (gid)
>insert into error_union_empty2
>select ST_CollectionExtract(ST_union(f_polygon.geom,f_polygon.geom,
>0.001152)) geom
>from f_polygon;
>Why is not working the first approach? Have I missed something in the
>query?
>Any help or comments are welcome.
>Does anyone knows if is expected to have a simplify with gridsize in
>the future?
>Thanks!
>Este correo electrónico y, en su caso, cualquier fichero anexo al
>mismo, contiene información de carácter confidencial exclusivamente
>dirigida a su destinatario o destinatarios. Si no es vd. el
>destinatario indicado, queda notificado que la lectura, utilización,
>divulgación y/o copia sin autorización está prohibida en virtud de la
>legislación vigente. En el caso de haber recibido este correo
>electrónico por error, se ruega notificar inmediatamente esta
>circunstancia mediante reenvío a la dirección electrónica del
>remitente.
>Evite imprimir este mensaje si no es estrictamente necesario.
>This email and any file attached to it (when applicable) contain(s)
>confidential information that is exclusively addressed to its
>recipient(s). If you are not the indicated recipient, you are informed
>that reading, using, disseminating and/or copying it without
>authorisation is forbidden in accordance with the legislation in
>effect. If you have received this email by mistake, please immediately
>notify the sender of the situation by resending it to their email
>address.
>Avoid printing this message if it is not absolutely necessary.
>_______________________________________________
>postgis-users mailing list
>postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
>https://lists.osgeo.org/mailman/listinfo/postgis-users
>remitente.
>address.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210415/9ebc7752/attachment.html>
