[postgis-users] Error: "Precision reduction requires GEOS-3.9 or higher"
Paul Ramsey pramsey at cleverelephant.ca
Fri Apr 16 14:58:38 PDT 2021
It's curious, but the implication is that the postgis on your machine was built against an earlier GEOS. The version number that postgis reports for GEOS is generated at run-time, while the test of whether to include support for various functions is determined at compile-time. Hence you can see a "GEOS 3.9" version in your postgis, but still not have access to functions that are 3.9+ only.
P
> On Apr 16, 2021, at 2:53 PM, Marco Boeringa <marco at boeringa.demon.nl> wrote:
> Hi all,
> I upgraded my Ubuntu 20.04 instance with "libgeos-3.9.0" from the ubuntugis repository.
> When I use:
> "SELECT PostGIS_Full_Version();"
> I get back:
> POSTGIS="3.1.1 aaf4c79" [EXTENSION] PGSQL="130" GEOS="3.9.0-CAPI-1.16.2" PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
> which at least suggests I am now correctly using GEOS 3.9.0 (note: I updated the PostGIS extension's functions using "ALTER EXTENSION postgis UPDATE")
> However, after adjusting some existing code to include the new "ST_ReducePrecision" PostGIS function (https://postgis.net/docs/ST_ReducePrecision.html), which is new in 3.9.0, I get back an error:
> which seems weird given the "PostGIS_Full_Version" result. Anyone have a clue as to what I missed?
> Marco
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
