[postgis-users] Error: "Precision reduction requires GEOS-3.9 or higher"
Marco Boeringa
marco at boeringa.demon.nl
Fri Apr 16 14:53:20 PDT 2021
Hi all,
I upgraded my Ubuntu 20.04 instance with "libgeos-3.9.0" from the
ubuntugis repository.
When I use:
"SELECT PostGIS_Full_Version();"
I get back:
POSTGIS="3.1.1 aaf4c79" [EXTENSION] PGSQL="130" GEOS="3.9.0-CAPI-1.16.2"
PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3"
WAGYU="0.5.0 (Internal)"
which at least suggests I am now correctly using GEOS 3.9.0 (note: I
updated the PostGIS extension's functions using "ALTER EXTENSION postgis
UPDATE")
However, after adjusting some existing code to include the new
"ST_ReducePrecision" PostGIS function
(https://postgis.net/docs/ST_ReducePrecision.html), which is new in
3.9.0, I get back an error:
which seems weird given the "PostGIS_Full_Version" result. Anyone have a
clue as to what I missed?
Marco
