[postgis-users] Fast spatial join point to raster
Paul Ramsey
pramsey at cleverelephant.ca
Sun Apr 18 11:21:43 PDT 2021
The indexing of rasters is (and remains a pain in the butt) (maybe something I should look at shortly) because the index is bound to geometry and almost always declraed functionally. You've built functional indexes,
GIST (ST_Transform(ST_Envelope(rast),26915))
But you aren't calling them with queries that use the SAME functional signature. The rule of functional indexes:
* An index like this: CREATE INDEX foo_x ON (function(bar))
* must be called like this: SELECT * FROM foo WHERE function(bar) = 'baz'
Note that function(bar) appears in the CREATE and in the SELECT.
P
> On Apr 18, 2021, at 10:53 AM, David Haynes <haynesd2 at gmail.com> wrote:
> Hello,
> I'm following up on this blog post to see if there is a fast way to join points to rasters.
> http://blog.cleverelephant.ca/2018/09/postgis-external-storage.html
> I'm attempting to do a dasymetric mapping process, which is assigning areal unit values to raster pixels. For this example, I have created two tables. Table 1, mn_smokers has are geom (x,y) coordinates and spatial indices on 4326 and 26915. The resulting raster will be stored in mn_dasymetric and it also has indices at 4326 and 26915. When running the explain query it seems that index isn't really being used.
> CREATE INDEX mn_smokers_gist_4326 ON mn_smokers USING GIST (geom);
> CREATE INDEX mn_smokers_gist_26915 ON mn_smokers USING GIST (ST_Transform(geom,26915));
> CREATE INDEX mn_dasymetric_gist_4326 ON mn_dasymetric USING GIST (ST_Transform(ST_Envelope(rast),4326));
> CREATE INDEX mn_dasymetric_gist_26915 ON mn_dasymetric USING GIST (ST_Transform(ST_Envelope(rast),26915));
> Type: Nested Loop (Inner); ; Cost: 6.22 - 1594516.11
> Type: Limit; ; Cost: 5.11 - 6.22
> Type: Nested Loop (Inner); ; Cost: 5.11 - 471.95
> Type: Seq Scan; Rel: minnesota_counties ; Cost: 0.00 - 34.09
> Type: Bitmap Heap Scan; Rel: mn_smokers ; Cost: 5.11 - 437.50
> Type: Bitmap Index Scan; Rel: mn_smokers_gist_4326 ; Cost: 0.00 - 5.10
> Type: CTE Scan; Rel: points ; Cost: 0.00 - 4.00
> Type: Materialize; ; Cost: 0.00 - 59.57
> Type: Seq Scan; Rel: mn_dasymetric ; Cost: 0.00 - 47.38
> with points as
> select sp_id as point_id, smoker as point_value, ms.geom
> from mn_smokers ms
> inner join minnesota_counties mc on ST_Intersects(ms.geom, mc.geom)
> , point_raster_agg as
> select geom, count(point_id) as pixel_point_value
> from points
> group by geom
> , output_rast as
> select r.rid, pixel_point_value, ST_SetValue(rast, ST_Transform(p.geom, 26915), pixel_point_value ) as setrast
> ,rast, geom
> from point_raster_agg p
> inner join mn_dasymetric r on ST_intersects(r.rast, ST_Transform(p.geom, 26915))
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
