[postgis-users] ST_Split precision issue?
Nicol Hermann postgis at geoworld.de
Sun Apr 25 07:36:03 PDT 2021
Hello List,
I am trying to split a linestring at an intersection to another line
into it's two segments.
This works as expected with "dummy" coordinates, but fails with "real-
world" coordinates.
This:
SELECT ST_AsText( ST_Split (ST_GeomFromText('LINESTRING(0 0,2 2)'),
ST_GeomFromText('POINT(1 1)') ) ) as lsegments;
gives me the expected output:
                          lsegments
 GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(1 1,2 2))
(1 Zeile)
When I am trying this with real world coordinates I am always getting
the un-splitted original linesting back.
Sample:
SELECT ST_AsText(ST_intersection(aline, bline)) AS
wktcut
FROM (SELECT
    ST_GeomFromText('LINESTRING(8.39567520433486
49.4224277276901,8.39591232763397 49.4198517063953)') As aline,
    ST_GeomFromText('LINESTRING(8.39481293779266
49.4206708596104,8.39717339245195 49.4208001995917)') As bline ) As
foo;
returns
POINT(8.39583178549713 49.4207266868819)
If I am using this in the split command
(ST_GeomFromText('LINESTRING(8.39567520433486
49.4224277276901,8.39591232763397 49.4198517063953)'),
ST_GeomFromText('POINT(8.39583178549713 49.4207266868819)') ) ) as
lsegments;
the result is
lsegments
 GEOMETRYCOLLECTION(LINESTRING(8.39567520433486
49.4224277276901,8.39591232763397 49.4198517063953))
(1 Zeile)
which es equal to the input.
Is this a precision issue between differen postgis functions and how
can I solve this?
If I'am adding ST_Snap it returns a linestring which only represents
one of the 2 segments I would expect.
See:
SELECT
 ST_AsText(
  ST_Split (
   ST_Snap (
ST_GeomFromText('POINT(8.39583178549713 49.4207266868819)'), 1 ),
as lsegments;
response is:
lsegemts
49.4224277276901,8.39583178549713 49.4207266868819))
Any hints, or do I have a misconception how ST_Split should work?
Thanks
Nicol
