[postgis-users] Postgis trigger : table and materialized view
celati Laurent
laurent.celati at gmail.com
Tue Aug 10 12:44:57 PDT 2021
Good evening,
I have a postgis polygons table for my "cities".
I have a point table for my "boreholl".
I created a "mv" materialized view defined by a spatial join as follows:
SELECT boreholl.*,
> cities.gid,
> cities.insee_id,
> cities.name
> FROM boreholl, cities
> WHERE st_intersects(boreholl.geom, cities.geom);
Now I want as soon as an updating takes place for the "cities_name" column
of my "cities" polygon table,
this change also occurs in the "name" column of my materialized view.
As far i understood,the trigger must be defined on the "cities" table as
follows :
CREATE TRIGGER cities_trigger
> after update
> on cities
> FOR EACH STATEMENT.
> execute procedure trigger_fonction
Now I need to define the function. It is for this step that I need you.
Below, a proposed structure. But a lot is missing :
CREATE or replace FUNCTION trigger_fonction
returns trigger
langage sql
AS $$
BEGIN
if then
update
end if ;
return new
refresh materialized view
END;
Thanks a lot.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210810/64e41597/attachment.html>
