[postgis-users] Postgis trigger : table and materialized view
Hugues François
hugues.francois at inrae.fr
Wed Aug 11 07:49:39 PDT 2021
Hi Laurent,
I'm may not understand your concern but I think I do the same kind of thing and it seems quite simple (since the materialized view do the job, there's no need to use any special trigger parameters).
Here is my trigger:
CREATE TRIGGER update_nbup
AFTER INSERT OR DELETE OR UPDATE
ON pasto.clim_definition_terr
FOR EACH STATEMENT
EXECUTE PROCEDURE pasto.update_nbup();
And the function executed
CREATE FUNCTION pasto.update_nbup()
RETURNS trigger
LANGUAGE 'plpgsql'
AS $$
BEGIN
REFRESH MATERIALIZED VIEW pasto.clim_definition_territoire;
return null;
END;
HTH
Hug
De: "celati Laurent" <laurent.celati at gmail.com>
À: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Envoyé: Mardi 10 Août 2021 21:44:57
Objet: [postgis-users] Postgis trigger : table and materialized view
Good evening,
I have a postgis polygons table for my "cities".
I have a point table for my "boreholl".
I created a "mv" materialized view defined by a spatial join as follows:
SELECT boreholl.*,
cities.gid,
cities.insee_id,
[ http://cities.name/ | cities.name ]
FROM boreholl, cities
WHERE st_intersects(boreholl.geom, cities.geom);
Now I want as soon as an updating takes place for the "cities_name" column of my "cities" polygon table,
this change also occurs in the "name" column of my materialized view.
As far i understood,the trigger must be defined on the "cities" table as follows :
BQ_BEGIN
CREATE TRIGGER cities_trigger
after update
on cities
FOR EACH STATEMENT.
execute procedure trigger_fonction
BQ_END
Now I need to define the function. It is for this step that I need you.
Below, a proposed structure. But a lot is missing :
BQ_BEGIN
CREATE or replace FUNCTION trigger_fonction
returns trigger
langage sql
AS $$
BEGIN
if then
update
end if ;
return new
refresh materialized view
END;
BQ_END
Thanks a lot.
[Fichier texte:ATT00001]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210811/4b4233d9/attachment.html>
