[postgis-users] soft breaklines (constrained delaunay)
Donovan Cameron
sault.don at gmail.com
Tue Aug 10 15:38:29 PDT 2021
I've been searching for a method to generate a TIN from three inputs,
including soft breaklines that don't have a z-value:
1.) Contour (3d line)
2.) height point (3d point)
3.) soft breakline (2d line)
Inputs 1 and 2 have z-values in ELEVATION column, whereas input 3 has no
z-value and is used to maintain those edge type features in the
resulting TIN/DEM.
The soft breaklines represent features like lake edges, streams, roads,
and other 'edge' type features in the TIN.
I have some sample data I could get together to share if needed.
I've done it in the past using v.triangle[1] from GRASS GIS.
Constrained Delaunay Triangles [2] are part of the underlying theory I
think when computing these with soft breaklines.
Donovan
[1] https://grasswiki.osgeo.org/wiki/TIN_with_breaklines
[2] http://postgis.net/docs/ST_ConstrainedDelaunayTriangles.html
