[postgis-users] Installing pgdg Postgis 3.1 on CentOS/Rhel7 breaks sqlite3 cli
Josiah Ulfers
josiah.ulfers at nltgis.com
Wed Aug 18 13:40:04 PDT 2021
Hi, it seems that yum-installing Postgis 3.1 on CentOS 7 or Rhel 7 causes
the sqlite3 command to exit with error anytime it's invoked. Is this a
bug, by design, or am I missing something?
On a fresh CentOS 7:
$ sqlite3 --version
3.7.17 2013-05-20 00:56:22 118a3b35693b134d56ebd780123b7fd6f1497668
$ yum install epel-release
https://download.postgresql.org/pub/repos/yum/reporpms/EL-7-x86_64/pgdg-re
dhat-repo-latest.noarch.rpm
$ yum install postgis31_12
$ sqlite3 --version
SQLite header and source version mismatch
2019-10-10 20:19:45
18db032d058f1436ce3dea84081f4ee5a0f2259ad97301d43c426bc7f3dfalt1
Postgis depends on a custom sqlite33 package from pgdg:
$ yum list installed sqlite*
sqlite.x86_64 3.7.17-8.el7_7.1 @anaconda
sqlite33.x86_64 3.30.1-6.rhel7 @pgdg-common
sqlite33-libs.x86_64 3.30.1-6.rhel7 @pgdg-common
And it seems that sqlite33 puts its libraries on the load path before the
default sqlite rpm that ships with CentOS and Rhel 7, but sqlite33 doesn't
replace the default sqlite3 executable:
$ cat /etc/ld.so.conf.d/sqlite33-pgdg-libs.conf
/usr/sqlite330/lib/
$ which sqlite3
/bin/sqlite3
$ find / -name sqlite3
/usr/bin/sqlite3
/usr/lib64/python2.7/sqlite3
/usr/sqlite330/bin/sqlite3
Workaround 1: ensure the default libraries get priority
$ LD_LIBRARY_PATH=/usr/lib64 sqlite3 --version
Workaround 2: invoke the sqlite3 from the pgdg package
$ /usr/sqlite330/bin/sqlite3 --version
3.30.1 2019-10-10 20:19:45
This feels like a bug in the rpm packaging, though other ideas are
welcome. Assuming it's not intentional, is https://trac.osgeo.org/postgis/
a good place to file it, or is somewhere else more appropriate?
Thanks
