[postgis-users] polygons inside polygon
Shaozhong SHI
shishaozhong at gmail.com
Wed Dec 1 03:28:28 PST 2021
This is interesting.
Can we have an SQL to produce report on the status of polygon? Namely, can
we write a script to tell us whether a geometry is a valid single geometry,
or polygons inside polygon, whether there be any issues such as
self-intersect in a polygon?
SQL reporting on geometry is of interest.
Is it possible to send me a small file of polygons inside polygon in a
format of CSV or Well Known Text, so that I can test out and confirm the
robustness of SQL scripts?
Regards,
David
On Tue, 30 Nov 2021 at 06:30, <paul.malm at lfv.se> wrote:
> Hi,
> I have a polygon layer where polygons are inside other polygons (could be
> polygons in polygons in polygons…).
> I would like to separate them in 2 different layers, one layer with the
> outer most polygon and one layer with all polygons that has a surrounding
> polygon.
> Is there a smart way to do this in SQL?
> Thanks,
> Paul
> [image: 1_LFV_svensk_96]
> Paul Malm
> Operations / AIM Flyginfo SE
> Direkt 08-797 70 23 Mobil 070-860 11 15
> paul.malm at lfv.se
> Besöks- och postadress
> LFV Flyginfo SE
> Af Pontins väg 6
> 115 21 STOCKHOLM
> Tänk på miljön innan du skriver ut detta e-postmeddelande.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211201/5d348d4d/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211201/5d348d4d/attachment.jpg>
