[postgis-users] polygons inside polygon
Nicolas Ribot nicolas.ribot at gmail.com
Wed Dec 1 06:13:15 PST 2021
Hi David,
You can use st_isValidReason(geom) to inspect an invalid geometry.
Predicates like st_contains, st_overlaps, st_intersects, etc. can give you
information about relationship between geometries. They all originate from
st_relate (http://postgis.net/docs/ST_Relate.html)
Nicolas
On Wed, 1 Dec 2021 at 12:29, Shaozhong SHI <shishaozhong at gmail.com> wrote:
> This is interesting.
> Can we have an SQL to produce report on the status of polygon?  Namely,
> can we write a script to tell us whether a geometry is a valid single
> geometry, or polygons inside polygon, whether there be any issues such as
> self-intersect in a polygon?
> SQL reporting on geometry is of interest.
> Is it possible to send me a small file of polygons inside polygon in a
> format of CSV or Well Known Text, so that I can test out and confirm the
> robustness of SQL scripts?
> Regards,
> David
> On Tue, 30 Nov 2021 at 06:30, <paul.malm at lfv.se> wrote:
>> Hi,
>> I have a polygon layer where polygons are inside other polygons (could be
>> polygons in polygons in polygons…).
>> I would like to separate them in 2 different layers, one layer with the
>> outer most polygon and one layer with all polygons that has a surrounding
>> polygon.
>> Is there a smart way to do this in SQL?
>> Thanks,
>> Paul
>>     [image: 1_LFV_svensk_96]
>>   Paul Malm
>>   Operations / AIM Flyginfo SE
>>   Direkt  08-797 70 23  Mobil 070-860 11 15
>>   paul.malm at lfv.se
>>    Besöks- och postadress
>>    LFV Flyginfo SE
>>    Af Pontins väg 6
>>    115 21 STOCKHOLM
>>    Tänk på miljön innan du skriver ut detta e-postmeddelande.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211201/187c9d4f/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211201/187c9d4f/attachment.jpg>
