[postgis-users] polygons inside polygon
Nicolas Ribot nicolas.ribot at gmail.com
Wed Dec 1 06:10:04 PST 2021
Hi Paul,
I often use a CTE to update values for a table:
with tmp as (
    select distinct p1.id, p2.id is null as outer_pg
    from org p1
     left join org p2 on p1.id <> p2.id and st_within(p1.geom, p2.geom)
) update org o set outer_pg = t.outer_pg
from tmp t
where o.id = t.id;
Nicolas
On Wed, 1 Dec 2021 at 11:10, <paul.malm at lfv.se> wrote:
> Thanks Nicolas,
> I’ve added a boolean column (outer_pg) in my original layer (org).
> Then I tried to populate that column, but it I don’t have the skills…
> I tried to use your selection:
> SELECT DISTINCT p1.fid, p2.fid IS null AS "outer_pg"
> FROM org p1
>      LEFT JOIN org p2 ON p1.fid <> p2.fid AND st_within(p1.the_geom,
> p2.the_geom)
> order by p1.fid;
> My try to populate outer_pg:
> UPDATE org
> SET "outer_pg" =  (SELECT outer_p FROM (
> SELECT DISTINCT p1.fid, p2.fid IS null AS outer_p
> from org p1
> p2.the_geom) WHERE p1.fid = org.fid) AS tmp)
> But that is not correct, do you have any suggestions?
> Kind regards,
> Paul
> *Från:* postgis-users <postgis-users-bounces at lists.osgeo.org> *För *Nicolas
> Ribot
> *Skickat:* den 30 november 2021 19:17
> *Till:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Ämne:* Re: [postgis-users] polygons inside polygon
> *Klicka bara på länkar och öppna bilagor om du litar på avsändaren och vet
> att innehållet är säkert.*
> Hi,
> What about a simple left join on the table searching for polygons
> contained inside other polygon ?
> Polygons that are contained inside other polygons will have false for the
> outer_pg column and true if they are not contained (ie are outer polygons).
> You can then create the tables you want based on the outer_pg values
> from polygon p1
>      left join polygon p2 on p1.id <> p2.id and *st_within*(p1.geom, p2.geom)
> order by p1.id;
> id       outer_pg
> 1        true
> 2        true
> 3        true
> 4        true
> 5        false
> 6        false
> 7        false
> 8        true
> 9        true
> 10       true
> 11       false
> Nicolas
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211201/109ccab7/attachment.html>
