[postgis-users] Not able to use properly custom projection
andy
aborruso at gmail.com
Thu Dec 16 01:57:24 PST 2021
I have a NTV2 file, and it works properly if I hardcode the parameters in
the query:
SELECT ST_AsText(
ST_Transform(
ST_GeomFromText('POINT(13.335462 41.132282)',4326),3004
) AS not_corrected,
ST_AsText(
ST_Transform(
'+proj=tmerc +lat_0=0 +lon_0=15 +k=0.9996 +x_0=2520000
+y_0=0 +ellps=intl
+nadgrids=40441123_43581445_R40_F00.gsb +units=m +no_defs'
) AS corrected;
The output is:
- POINT(2380292.276247742 4554785.392090227)
- POINT(2380294.3337390865 4554784.22045453)
If I insert it in PostGIS
-- create new record
insert into public.spatial_ref_sys (srid, auth_name, auth_srid, srtext,
proj4text) select 93004 , auth_name, auth_srid, srtext, proj4text from
spatial_ref_sys where srid = 3004;
-- update it
update spatial_ref_sys set proj4text = '+proj=tmerc +lat_0=0 +lon_0=15
+k=0.9996 +x_0=2520000 +y_0=0 +ellps=intl
+nadgrids=40441123_43581445_R40_F00.gsb +units=m +no_defs' where srid =
93004
and then I run
SELECT ST_AsText(
ST_Transform(
) AS not_corrected,
ST_AsText(
ST_Transform(
ST_GeomFromText('POINT(13.335462 41.132282)',4326),93004
) AS corrected;
I obtain two equal results, as if it did not apply what was read in the
proj string in spatial_ref_sys:
I'm using PostgreSQL 13.5, compiled by Visual C++ build 1914, 64-bit, 3.1
USE_GEOS=1 USE_PROJ=1 USE_STATS=1
I can't figure out what the problem could be. Why does it work hardcoded
and not via spatial_ref_sys?
Thank you
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211216/a2ef4e08/attachment.html>
