[postgis-users] Not able to use properly custom projection
Florian Nadler
florian.nadler at cybertec.at
Thu Dec 16 03:39:47 PST 2021
depending on the parameters you defined in spatial_ref_sys, PostGIS
decides how to process the transformation, see
https://blog.cleverelephant.ca/2019/02/proj4-postgis.html
Try to define proj4text only:
insert into public.spatial_ref_sys (srid,proj4text)
select 93004,proj4text from spatial_ref_sys where srid =3004;
update spatial_ref_sys set proj4text ='+proj=tmerc +lat_0=0 +lon_0=15 +k=0.9996 +x_0=2520000 +y_0=0
+ellps=intl +nadgrids= +units=m +no_defs' where srid =93004; Florian
Am 16.12.2021 um 10:57 schrieb andy:
> Hi,
> I have a NTV2 file, and it works properly if I hardcode the parameters
> in the query:
> SELECT ST_AsText(
> ST_Transform(
> ST_GeomFromText('POINT(13.335462 41.132282)',4326),3004
> ) AS not_corrected,
> ST_AsText(
> ST_Transform(
> +y_0=0 +ellps=intl
> +nadgrids=40441123_43581445_R40_F00.gsb +units=m +no_defs'
> ) AS corrected;
> The output is:
> - POINT(2380292.276247742 4554785.392090227)
> - POINT(2380294.3337390865 4554784.22045453)
> If I insert it in PostGIS
> -- create new record
> insert into public.spatial_ref_sys (srid, auth_name, auth_srid,
> srtext, proj4text) select 93004 , auth_name, auth_srid, srtext,
> proj4text from spatial_ref_sys where srid = 3004;
> -- update it
> update spatial_ref_sys set proj4text = '+proj=tmerc +lat_0=0 +lon_0=15
> +k=0.9996 +x_0=2520000 +y_0=0 +ellps=intl
> +nadgrids=40441123_43581445_R40_F00.gsb +units=m +no_defs' where srid
> = 93004
> and then I run
> SELECT ST_AsText(
> ST_Transform(
> ) AS not_corrected,
> ST_AsText(
> ST_Transform(
> ST_GeomFromText('POINT(13.335462 41.132282)',4326),93004
> ) AS corrected;
> I obtain two equal results, as if it did not apply what was read in
> the proj string in spatial_ref_sys:
> I'm using PostgreSQL 13.5, compiled by Visual C++ build 1914,
> 64-bit, 3.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> I can't figure out what the problem could be. Why does it work
> hardcoded and not via spatial_ref_sys?
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
> in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
CYBERTEC PostgreSQL International GmbH
Römerstraße 19, A-2752 Wöllersdorf
Web:https://www.cybertec-postgresql.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211216/604490f9/attachment.html>
