[postgis-users] Contradiction between ST_IsValid() and ST_IsValidReason() ?
Andreas Neumann
a.neumann at carto.net
Tue Jan 5 02:04:02 PST 2021
Hi Strk,
Please apologize my delay in responding.
I just retested with the latest master - and unfortunately the problem
still persists.
I opened a new ticket: https://trac.osgeo.org/postgis/ticket/4825
It might be a different issue than
https://trac.osgeo.org/postgis/ticket/4825 [1]
I would appreciate if you could have a look at it.
Thanks,
Andreas
On 2021-01-03 00:26, Sandro Santilli wrote:
> On Thu, Dec 24, 2020 at 11:05:22AM +0100, Sandro Santilli wrote: On Wed, Dec 23, 2020 at 05:38:23PM +0100, Andreas Neumann wrote: Hm, seems like it is still not good in master.
> As soon as I add "ST_MakeValid()" in the same SQL query, it goes back to
> "weird" mode.
> Then there must be another memory issue. It would help to have a
> sample of geoms which can still reproduce the problem.
Andreas: could you check current master branch ?
See https://trac.osgeo.org/postgis/ticket/4823
--strk;
Links:
[1] https://trac.osgeo.org/postgis/ticket/4825
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210105/faa2a980/attachment.html>
