[postgis-users] Various ways to handle addresses in postgresql
Shaozhong SHI shishaozhong at gmail.com
Sat Jan 9 07:24:47 PST 2021
Hi, Stephen,
Please send me the link to libpostal.  I also need information on how to
instal it one PostGIS.  I need the information to instruct our ICT staff,
so that they can make it ready.
Regards,
David
On Sat, 9 Jan 2021 at 15:04, Stephen Woodbridge <
stephenwoodbridge37 at gmail.com> wrote:
> Or use libpostal as Komяpa suggested and I’m sure there are others also.
> I’m just familiar with my own code and the fact that I built it to work
> inside a postgresql database.
> Sent from my iPhone
> On Jan 9, 2021, at 10:00 AM, Stephen Woodbridge <
> David,
> Yup and this is just one a dozens of cases that you have to deal with. You
> are dealing with a natural language processing problem. And you have to
> deal with human input that has typos and abbreviations.
> These issues are what the address standardizer fixes. It tokenized the
> address and uses the gazette to standardize the terms and then classifies
> each term and assigns it to part of the address based on a grammar.
> So there is a simple solution, use my address standardizer, it is free,
> MIT license, it has a sample lexicon/ gazette and grammar for the UK, it is
> easy to modify these to fit your needs, and it just works. Oh if you want
> to do another county it also has sample files for 25 countries.
> Sent from my iPhone
> On Jan 9, 2021, at 4:42 AM, Darafei Komяpa Praliaskouski <me at komzpa.net>
> wrote:
> Hello,
> People make neural networks for this kind of task:
> https://github.com/openvenues/libpostal
> сб, 9 сту 2021, 12:40 карыстальнік Shaozhong SHI <shishaozhong at gmail.com>
> напісаў:
>> Hi, Steve W,
>> it is easy to parse addresses as tokens.  But it is difficult to put
>> tokens in right columns, due to that the same address could be expressed
>> with partial address or full address.
>> The same address can be written like,  Flat 1 122 Great Avenue London UK,
>> or Flat 1 122 Greet Avenue Central London London United Kingdom.
>> When this happens, each address has different number of tokens, so
>> different numbers of tokens.  Is there a way to deal with this issue so
>> that each token can get into right column?
>> Please enlighten me.
>> Regards,
>> David
>> On Sat, 25 Apr 2020 at 05:09, Stephen Woodbridge <
>>> And I have create an address-standardizer project here
>>> https://github.com/woodbri/address-standardizer which is user
>>> configurable. I might be over kill is you just want to strip off the
>>> number, in which case you might just use a SQL regexp replace to remove
>>> it.
>>> -Steve W
>>> On 4/25/2020 12:04 AM, Stephen Woodbridge wrote:
>>> > PostGIS has address_standardizer extension that includes
>>> > parse_address() and standardize_address() functions.
>>> > -Steve W
>>> >> maybe you can use the https://github.com/openvenues/libpostal library
>>> >> with your favorite language bindings ( Python / Ruby / Go / PHP /
>>> >> Node / R / Java  ...)
>>> >> or as a Postgres database extension:
>>> https://info.crunchydata.com/blog/quick-and-dirty-address-matching-with-libpostal
>>> >> https://github.com/pramsey/pgsql-postal
>>> >> Regards,
>>> >>  Imre
>>> >> <mailto:shishaozhong at gmail.com>> ezt írta (időpont: 2020. ápr. 25.,
>>> >> Szo, 2:49):
>>> >>     I find this is a simple, but important question.
>>> >>     How best to split numbers and the rest of address?
>>> >>     For instance, one tricky one is as follows:
>>> >>     21-1 Great Avenue, a city, a country, this planet
>>> >>     How to turn this into the following:
>>> >>     column 1,       column 2
>>> >>     Note:  there is a hyphen in  21-1
>>> >>     Any clue?
>>> >>     Regards,
>>> >>     Shao
>>> >>     _______________________________________________
>>> >>     postgis-users mailing list
>>> >>     postgis-users at lists.osgeo.org <mailto:
>>> postgis-users at lists.osgeo.org>
>>> >>     https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210109/8de3d983/attachment.html>
