[postgis-users] Creating a boundary of an aggregate of buildings
Luca Bertoncello
lucabert at lucabert.de
Mon Jan 18 04:02:31 PST 2021
Am 18.01.2021 12:48, schrieb Tomas Straupis:
Hi Tomas,
> Are you sure you're getting a combined multigeometry before applying
> buffer+-? All small polygons which you expect to be aggregated into
> one should be in one geometry (one row) before doing buffering.
No, I'm not... :) Sorry, I'm really a beginner with PostGIS and
OpenStreetMaps...
> 1. Increase buffer size.
> 2. ST_ConvexHull, ST_ConcaveHull.
> Here is a working forest aggregation routine.
> create table gen_forest as
> select nextval('gen_forest_seq') AS id
> ,0::bigint AS way_area
> ,10 AS res
> ,ST_CollectionExtract(unnest(ST_ClusterWithin(way, 10)),
> 3)::geometry(MultiPolygon, 3857) as way
> from planet_osm_polygon
> where landuse = 'forest';
> delete from gen_forest where st_area(st_buffer(way, -10)) < 10 and res
> = 10;
> update gen_forest set way =
> st_makevalid(st_multi(st_simplifypreservetopology(st_buffer(st_buffer(way,
> 10, 'quad_segs=1'), -10, 'quad_segs=1'), 10))) where res = 10;
> update gen_forest set way_area = st_area(way) where res = 10;
I'll try to create a table with landuse = 'residential' (and the other),
then use this table to generate the boundaries...
Do I understand correctly, you create areas with "forests" and distance
not greater than 10 meters?
I'll report to the list the result.
Thanks
Luca Bertoncello
(lucabert at lucabert.de)
