[postgis-users] Creating a boundary of an aggregate of buildings
Luca Bertoncello
lucabert at lucabert.de
Mon Jan 18 06:01:14 PST 2021
Am 18.01.2021 14:38, schrieb Tomas Straupis:
Hi
> This statement has problems.
> You're adding a buffer of 10 then removing a buffer of 500 (so
> basically leaving only very large polygons and they are eroded by
> 500meters). Then you're simplifying the result with a 500m value (a
> lot).
> Try this:
> UPDATE city_boundaries
> SET way = ST_Makevalid(ST_Multi(ST_Buffer(ST_Buffer(way, 400,
> 'quad_segs=1'), -400, 'quad_segs=1')));
I tried this:
CREATE TABLE city_boundaries AS
SELECT NEXTVAL('city_boundaries_seq') AS id
,0::bigint AS way_area
,10 AS res
,ST_CollectionExtract(unnest(ST_ClusterWithin(way, 400)),
3)::geometry(MultiPolygon, 3857) as way
FROM planet_osm_polygon
WHERE landuse IN ('residential', 'retail', 'retail;residential',
'commercial', 'school', 'university');
ALTER TABLE city_boundaries OWNER TO _renderd;
DELETE FROM city_boundaries WHERE ST_Area(ST_Buffer(way, -400)) < 400
and res = 10;
UPDATE city_boundaries SET way =
ST_Makevalid(ST_Multi(ST_Buffer(ST_Buffer(way, 400, 'quad_segs=1'),
UPDATE city_boundaries SET way_area = st_area(way) WHERE res = 10;
This will be better, but:
1) I have always many little areas
2) I miss some "medium areas"
3) the displayed areas have many "holes"
A possible solution to 2) could be to reduce the distance (let's say 200
meter instead of 400?) but so I'll increase the number of little areas.
I think a right way could be to reduce the distance (see previous) and
generate an area grouping all near little areas, filling the "inclosed"
holes in the areas. Then I can search for areas greater than for example
20 Km².
But I don't know to do that...
Thanks
Luca Bertoncello
(lucabert at lucabert.de)
