[postgis-users] Postgis 3.1.0 st_makevalid crashes the PostgreSQL Server
Fatih Sazan
fatihsazan01 at gmail.com
Sun Jan 24 23:19:42 PST 2021
When I run my code running on PostGIS version 2.5, I don't get an error but
when I run it on 3.1 it the server gives an error and enters the recovery
mode every time.
pgadmin4 messages:(*"Connection to the server has been lost."*).
postgresql log : "*WARNING: terminating connection because of crash
of another server process
DETAIL: The postmaster has commanded this server process to roll back
the current transaction and exit, because another server process
exited abnormally and possibly corrupted shared memory.
HINT: In a moment you should be able to reconnect to the database and
repeat your command.
WARNING: terminating connection because of crash of another server process
CONTEXT: SQL statement "SELECT (*
I have installed PostgreSQL on a separate server. Here I also get an error
that PostgreSQL crashes due to the PostGIS function (eg:st_makevalid). In
my opinion, there is a problem arising from the PostGIS version.
Can you try the queries yourself by trying on PostGIS extension versions
3.1.0 to 2.5?
I think we can see if there is a general problem of PostGIS 3.1.0 version.
PostGIS 3.1.0 - Query that raised an error:
select st_makevalid(
st_force2d(
st_multi(
st_buffer(st_setsrid(ST_GeomFromGeoJSON(geometry), 4326), 0)
)::geometry (multipolygon, 4326)
)from (
select j->'geometry' as geometry
from (
select (
'{"type":"Feature","geometry":{"type":"Polygon","coordinates":[[[39.75359,37.23446],[39.75359,37.23449],[39.75359,37.23415],[39.75391,37.23409],[39.7539,37.2341],[39.75373,37.23413],[39.75359,37.23446]]]}}'::json
) as j
) t1
) t1
PostGIS 3.1.0 - Query that works without any problem:
st_force2d(
st_multi(
)from (
from (
select (
'{"type":"Feature","geometry":{"type":"Polygon","coordinates":[[[28.89686,41.00149],[28.89698,41.00147],[28.89704,41.00157],[28.89693,41.0016],[28.89686,41.00149]]]}}'::json
) as j
) t1
) t1
Operating System: CentOS Linux 8
CPE OS Name: cpe:/o:centos:centos:8
Kernel: Linux 4.18.0-193.28.1.el8_2.x86_64
Architecture: x86-64
postgresql-13
extension : postgis vers. 3.1.0
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210125/84f3278a/attachment.html>
