[postgis-users] Corrupted topology: ring of edge x is geometrically not-closed
Diogo Marques
dmarques at infoportugal.impresa.pt
Thu Jan 28 02:28:51 PST 2021
Hello,
Seems there is a bug when trying to add some specific lines to a topology, you can find a SQL script that creates the necessary table and topology, and adds the lines in certain order. When adding the last line, an error occurs:
WARNING: Loading of record 5 failed: Corrupted topology: ring of edge -7 is geometrically not-closed
On the loop, if we order by id DESC, all lines are added to the topology.
This problem only occurs if it’s a 3D topology. If we work on 2D only, no error is raised.
We also tried to order the query with a subquery (the commented code), but always with the error, it seems the query is not being ordered.
DROP TABLE IF EXISTS lines;
CREATE TABLE lines (
id serial PRIMARY KEY,
geom geometry(LINESTRINGZ, 3763) NOT NULL
CREATE INDEX idx_lines_geom ON lines USING gist(geom);
INSERT INTO lines (geom) values
('01020000A0B30E000005000000295C8FC235C5F040295C8FC2BF8D0641713D0AD7A350774066666666FEC4F040B81E85EBD78D0641713D0AD7A350774015AE47E112C5F040E17A14AEE38D06417B14AE47E14E7740CDCCCCCC4CC5F040AE47E17ACA8D0641F6285C8FC24D7740295C8FC245C5F04067666666C68D064152B81E85EB4D7740'),
('01020000A0B30E000002000000295C8FC235C5F040295C8FC2BF8D0641713D0AD7A35077406666666626C5F040D7A3703DA08D0641AE47E17A14567740'),
('01020000A0B30E0000060000009A999999B1C4F0405C8FC2F59A8D064133333333338F7740C3F5285CC3C4F0403E0AD7A3B48D064133333333338F774000000000C8C4F0400AD7A370C98D064148E17A14AE8B77403333333307C5F0400AD7A370C98D064167666666668A774048E17A1406C5F0403E0AD7A3A68D064148E17A14AE8777409A99999911C5F0403E0AD7A3A48D0641C3F5285C8F867740'),
('01020000A0B30E0000020000009A99999911C5F0403E0AD7A3A48D0641C3F5285C8F8677406666666626C5F040D7A3703DA08D0641C3F5285C8F867740'),
('01020000A0B30E00000200000066666666FEC4F040B81E85EBD78D0641713D0AD7A3507740F6285C8FE6C4F0400AD7A370C98D06410000000000607740');
SELECT topology.droptopology('lines_topo')
WHERE EXISTS (
SELECT * FROM topology.topology WHERE name = 'lines_topo'
SELECT topology.CreateTopology('lines_topo', 3763, 0, true);
SELECT topology.AddTopoGeometryColumn('lines_topo', 'public', 'lines', 'topo', 'LINE');
-- UPDATE lines
-- SET topo = topology.totopogeom(geom, 'lines_topo', 1, 0)
-- WHERE id in (
-- SELECT id
-- FROM lines
-- ORDER BY id DESC
-- FOR UPDATE
DO
DECLARE
id_line integer;
BEGIN
FOR id_line IN SELECT id FROM lines ORDER BY id --DESC
LOOP
BEGIN
UPDATE lines
WHERE id = id_line;
EXCEPTION
WHEN OTHERS THEN
RAISE WARNING 'Loading of record % failed: %', id_line, sqlerrm;
END;
END LOOP;
END
PS-> This has been tested on versions:
MacOS Catalina
POSTGIS=“3.0.2 2fb2a18” [EXTENSION] PGSQL=“120" GEOS=“3.8.1-CAPI-1.13.3” PROJ=“6.2.1" LIBXML=“2.9.10” LIBJSON=“0.13.1" LIBPROTOBUF=“1.3.2” WAGYU=“0.4.3 (Internal)” TOPOLOGY
Docker image - postgis/postgis:13-master
POSTGIS="3.1.0 3.1.0" [EXTENSION] PGSQL="130" GEOS="3.9.0-CAPI-1.14.1" PROJ="7.2.1" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.3.1" WAGYU="0.5.0 (Internal)" TOPOLOGY
Cheers,
Diogo Marques [http://newsletter.impresapublishing.pt/i/barra_ip.jpg]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210128/e32d5a6b/attachment.html>
