[postgis-users] Axis switching in transform from SRID 4326 to 3006 (Sweref99 TM) with PostGIS 3.1.3
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jul 21 13:29:01 PDT 2021
Also I can run your SQL against my working copy and the right answer is
there
postgis32=# SELECT ST_AsText(ST_Transform('SRID=3006;POINT(675117
6580677)', 4326)) ;
st_astext
POINT(18.078112692195987 59.32848233749213)
(1 row)
On Wed, Jul 21, 2021 at 1:25 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> The fix is not in any released version yet. If you pull the code from git
> and build you can confirm it works for your case (I'm going to guess that
> it will, your description matches the other N/E systems.
> P
> On Tue, Jul 20, 2021 at 5:12 PM David Stenwall <david.stenwall at icloud.com>
> wrote:
>> Hi
>> Ok, so I _think_ I have the same issue as in
>> https://trac.osgeo.org/postgis/ticket/4949 since Sweref99 is also an
>> N/E-type projection, also the National Projection of Sweden. I tried
>> updating to 3.1.3 but no success.
>> I’m using ST_Transform to convert between lat/long and Sweref99 but the
>> axis get reversed and a point in sweden ends up in the Indian ocean.
>> I’m using
>> "POSTGIS=""3.1.3 008d2db"" [EXTENSION] PGSQL=""130""
>> GEOS=""3.9.1-CAPI-1.14.2"" PROJ=""7.2.1"" LIBXML=""2.9.10""
>> LIBJSON=""0.15"" LIBPROTOBUF=""1.4.0"" WAGYU=""0.5.0 (Internal)"" TOPOLOGY"
>> Example
>> SELECT ST_AsText(ST_Transform('SRID=3006;POINT(675117 6580677)', 4326))
>> // Sweden National Museum
>> returns
>> "POINT(62.973291540292465 4.080735770719003)” // Somewhere east of Africa
>> That should be long/lat 18.078113 59.328482 according to epsg.io
>> So am I missing something or is the fix in 3.1.3 not working or is this a
>> similar problem but not the same thing?
>> Regards
>> David
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210721/9458bdb3/attachment.html>
