[postgis-users] RHEL-8 configure: error: could not find libpq
Jan Peters
haseningo at gmx.de
Tue Jul 27 23:06:42 PDT 2021
Hey Regina,
I found a solution:
dnf install redhat-rpm-config
that works for me
> Gesendet: Dienstag, 20. Juli 2021 um 21:33 Uhr
> Von: "Regina Obe" <lr at pcorp.us>
> An: "'PostGIS Users Discussion'" <postgis-users at lists.osgeo.org>
> Betreff: Re: [postgis-users] RHEL-8 configure: error: could not find libpq
> Maybe your PostgreSQL is not in system path for some reason. That could
> happen if you have multiple PostgreSQL installs.
> Try running configure passing path to your pg config like so:
> ./configure --with-pgconfig= /usr/pgsql-12/bin/pg_config
> > -----Original Message-----
> > From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> > Behalf Of Jan Peters
> > Sent: Monday, July 19, 2021 7:54 AM
> > To: postgis-users at lists.osgeo.org
> > Subject: [postgis-users] RHEL-8 configure: error: could not find libpq
> > Hello,
> > I would like to compile postgis under RedHat 8 Enterprise. Unfortunately
> the
> > current configure fails with the following error message:
> > checking for PQserverVersion in -lpq.... no
> > I have already installed the following packages
> > rpm -qa | grep libpq
> > libpq-devel-12.5-1.el8_3.s390x
> > libpq-12.5-1.el8_3.s390x
> > rpm -qa | grep postgresql
> > postgresql-server-12.5-1.module+el8.3.0+9042+664538f4.s390x
> > postgresql-12.5-1.module+el8.3.0+9042+664538f4.s390x
> > postgresql-server-devel-12.5-1.module+el8.3.0+9042+664538f4.s390x
> > postgresql-static-12.5-1.module+el8.3.0+9042+664538f4.s390x
> > ls -alh /usr/lib64/libpq.so*
> > lrwxrwxrwx 1 root root 13 Dec 1 2020 /usr/lib64/libpq.so -> libpq.so.5.12*
> > lrwxrwx 1 root root 13 Dec 1 2020 /usr/lib64/libpq.so.5 -> libpq.so.5.12*
> > rwxr-xr-x 1 root root 341K Dec 1 2020 /usr/lib64/libpq.so.5.12*
> > Can you guys help me with this problem?
> > Best Regards
> > Jan
> > postgis-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
