[postgis-users] Finding all 'adjacent' points in a point set
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jul 29 15:29:41 PDT 2021
Why are you materializing the tables in a CTE? Do a direct self-join
SELECT
p1.id as src,
p2.id as dest,
st_makeline(p1.geom,p2.geom) as geom,
FROM points p1, points p2
WHERE p1.id != p2.id -- don't link a point to itself
and ST_DWithin (p1.geom,p2.geom, 16 * 1.74 ) -- only link to nearest 6 points (spacing 16)
and p1.geom > p2.geom -- only link in one direction
And have an index on points, of course.
CREATE INDEX points_geom_x ON points USING GIST (geom);
> On Jul 29, 2021, at 3:25 PM, Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
> I have a table of points on a regular hexagon grid spacing. I need to create an edge table between every point and the points in its adjacent hexagon.
> Say the table is points with an id field and point geom. I am trying :
> WITH
> p1 as (select * from points),
> p2 as (select * from points)
> SELECT
> p1.id as src,
> p2.id as dest,
> FROM p1, p2
> and ST_dwithin (p1.geom,p2.geom, 16 * 1.74 ) -- only link to nearest 6 points (spacing 16)
> This works fine but gets really slow with lots of points. Is there a better way of attacking this problem?
> Thanks
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
