[postgis-users] PostGIS transforms st_dwithin to && on geography column without preserving the custom spatial reference system
Michael Loveridge loveridge at ascendingnode.tech
Tue Jun 1 12:09:24 PDT 2021
When I use st_dwithin on a geography column with a GIST index, the
explain plan shows that the narrowing condition on the index scan is
changed into a && bounding box condition. With this different condition,
the result set is missing rows that are included if a st_dwithin is
performed using a full table scan when there is no index.
The condition in the explain plan without an index is:
st_dwithin(
   geog,
   '010100002010A4000000000000006066400000000000000000'::geography,
   '3'::double precision,
   false
But the explain plan indicates that it is changed into the following
when the column has a GIST index:
geog && _st_expand(
The geography column has a custom spatial reference system that is not
being preserved in the transformation into a && condition. The custom
spatial reference system is a sphere where the radius is such that one
degree is equal to one meter of great-circle distance. So that a point
of (0 0) is one distance away from (0 1). But it seems that when using
st_dwithin, the search is being done in srid 4326 instead of my custom one.
The setup code is below:
-- Insert the custom spatial reference system into the db.
insert into spatial_ref_sys values (42000, 'customsrs', 1,
      'GEOGCS[
        "Normal Sphere (r=57.2957795)",
        DATUM["unknown",
          SPHEROID["Sphere",57.29577951308232087679,0]
        PRIMEM["Greenwich",0],
        CS[ellipsoidal,2],
        AXIS["latitude",north],
        AXIS["longitude",east],
        UNIT["degree",0.0174532925199433]
      ]', '+proj=longlat +ellps=sphere +R=57.29577951308232087679
+no_defs');
-- Create a new table with a geography column in the new spatial
reference system.
CREATE TABLE geographytest(gid serial PRIMARY KEY, geog geography(POINT,
42000));
-- Insert some data around the dateline
insert into geographytest (gid, geog) values
(1, 'srid=42000;POINT(179 0)'),
(2, 'srid=42000;POINT(178 0)'),
(3, 'srid=42000;POINT(-179 0)'),
(4, 'srid=42000;POINT(-179 90)'),
(5, 'srid=42000;POINT(0 0)');
-- Select all points within a distance of 3 from POINT(179 0).
--   The expected 3 points are returned, with st_distances of 0, 1 and 2.
select
  gid,
  st_distance(
    geog,
    'srid=42000;POINT(179 0)',
    false
  st_dwithin(
    geog,
    3,
    false
from
  geographytest
where
  st_dwithin(
    geog,
    st_geogfromtext('srid=42000;POINT(179 0)'),
    3,
    false
-- Create a GIST index on our geography column
CREATE INDEX geographytestindex ON geographytest USING gist (geog);
VACUUM analyze geographytest (geog);
-- Now select again using the same query.
--   Now only one result is returned, the row that has POINT(179 0).
--   The explain plan indicates that the index scan is using
--   Index Cond: (geog &&
_st_expand('010100002010A4000000000000006066400000000000000000'::geography,
'3'::double precision))
--   when performing the select.
select
  gid,
  st_distance(
    geog,
    false
  st_dwithin(
    geog,
    3,
    false
from
  geographytest
where
  st_dwithin(
    geog,
    3,
    false
Increasing the st_dwithin distance to 230000 instead of 3 returns all
three of the expected rows, since that is their distance in srid 4326.
How can I get PostGIS to use my custom spatial reference system in the
query when an index is present on the column?
