[postgis-users] ST_SquareGrid for known extent
    David Galt
    davidlgalt.gis+qlist at gmail.com
    Thu Jun 10 16:21:07 PDT 2021
Kinda. I was hoping to be able to use the st_SquareGrid and st_ HexagonGrid
functions. Something along the lines of
SELECT 0 as OGC_FID, hex.geom
FROM (SELECT * from st_makeenvelope(-9585017.66383462, 4580013.332495567,
-9498173.412746038, 4638341.318989425, 3857) ) geom)) env
CROSS JOIN ST_HexagonGrid(1609.344, env.geom) AS hex
WHERE ST_Intersects(env.geom, hex.geom)
On Thu, Jun 10, 2021 at 3:31 PM Simon Greener <simon at spdba.com.au> wrote:
> David,
> Are you after something like this?
> https://www.spdba.com.au/generating-a-grid-fishnet-of-points-or-polygons-for-postgis
> Simon
> Get BlueMail for Android <http://www.bluemail.me/r?b=16696>
> On 11 Jun 2021, at 06:34, David Galt <davidlgalt.gis+qlist at gmail.com>
> wrote:
>> Hi all,
>> I'm sure this is simple, but I have not found the answer. I'd like to use
>> the ST_SquareGrid function to create a grid not based on another layer but
>> on a known envelope.
>> e.g. st_makeenvelope(-9585017.66383462, 4580013.332495567,
>> How would I code this?
>> David Galt
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210610/76dc3e36/attachment.html>
