[postgis-users] Help resolving raster2pgsql error
Ben Boughton bboughton at gmail.com
Wed Jun 23 16:41:06 PDT 2021
I tried a clean install - this time with the UbuntuGIS-Unstable and
just did 'apt get install postgis' - I got postgis3 and postgresql12 and
raster2pgsql working.
Ben Boughton
On Wed, 23 Jun 2021 at 11:19, Regina Obe <lr at pcorp.us> wrote:
> > On Wed, 23 Jun 2021 at 08:32, Ben Boughton <bboughton at gmail.com> wrote:
> > > Processing 1/1: testr.tif
> > > ERROR 1: PROJ: proj_as_wkt: SQLite error on SELECT name,
> > > ellipsoid_auth_name, ellipsoid_code, prime_meridian_auth_name,
> > > prime_meridian_code, area_of_use_auth_name, area_of_use_code,
> > > publication_date, deprecated FROM geodetic_datum WHERE auth_name = ?
> > > AND code = ?: no such column: area_of_use_auth_name
> > You might have PROJ_LIB pointing to a different version of PROJ, as the
> schema
> > in proj.db has changed a few times between releases.
> > https://proj.org/usage/environmentvars.html#envvar-PROJ_LIB
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> [Regina Obe]
> As Mike noted, proj.db has changed a number of times in proj releases.
> Last person I ran into with this particular problem was because they got
> their proj from main distro
> And they had installed QGIS/GDAL via UbuntuGIS which installed a newer
> version of proj. So they had two versions of proj, but the proj.db path was
> the newer.
> It was a mess to properly fix the install, so I ended up just giving him my
> copy of proj.db to overwrite his.
> Lesson: Don't mix distributions of GDAL/PROJ.  Bad things happen.
> You can check which version of Proj your postgis is running with
> SELECT postgis_full_version();
> And whatever proj that says you should be using a proj.db that was built
> from that one.
> I've got a bunch of versions of proj hanging around, so I could give you my
> copy of proj.db for your version of Proj, if it comes to that.
> Hope that helps,
> Regina
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210624/43887626/attachment.html>
