[postgis-users] TR: postgis_restore.pl
Regina Obe
lr at pcorp.us
Sun Jun 27 10:49:09 PDT 2021
I would say you probably dont need it unless restoring from really old
system.
Are you restoring from a PostGIS 1.5 or PostGIS 2.0?
Even with those, it should be sufficient if your database was created with
scripts instead of extension to first
1) CREATE EXTENSION postgis;
--if your old backup is not in public, you may need to specify the schema
like so replace SCHEMA postgis with SCHEMA
name_of_schema_you_installed_postgis_in
CREATE EXTENSION postgis SCHEMA postgis;
CREATE EXTENSION postgis_topology;
2) Use pg_restore to restore your backup (or psql if its a plain text
backup)
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Alain Benard
Sent: Friday, June 25, 2021 2:20 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] TR: postgis_restore.pl
Hi ,
Because of problem with Postgres 12 / Postgis 2.5.5 on Centos 8 we test to
install Postgres 12 / Postgis 3.0.
In the pats i have used your script postgis_restore.pl and this script is
again present in the directory /usr/pgsql-12/share/contrib/postgis-3.0/. In
this script i find :
# # Copyright (C) 2009 Paul Ramsey <pramsey at cleverelephant.ca
<mailto:pramsey at cleverelephant.ca> >
# Tested on:
# pg-8.4.9/pgis-1.4.3 => pg-8.4.9/pgis-2.0.0SVN
# pg-8.4.9/pgis-2.0.0SVN => pg-8.4.9/pgis-2.0.0SVN
# pg-8.4.9/pgis-2.0.0SVN => pg-9.1.2/pgis-2.0.0SVN
# pg-9.1b3/pgis-1.5.3 => pg-9.1.1/pgis-2.0.0SVN
On the server postgis 2.5.5 i dump with Fc and on the new (Postgis3) i use
the script with some mistakes :
ERREUR: la relation « geometry_columns » n'existe pas
LIGNE 1 : UPDATE topology.topology t set srid = g.srid FROM geometry_c...
ERREUR: la relation « spatial_ref_sys » n'existe pas
LIGNE 1 : UPDATE spatial_ref_sys o set auth_name = n.auth_name, auth_s...
LIGNE 1 : INSERT INTO spatial_ref_sys SELECT * FROM _pgis_restore_spat...
It seems that the restore is ok but what is your opinion about using this
perl script today ??
Thank you for advance.
Alain.
Alain BENARD
Administrateur Systèmes dInformation
<mailto:alain.benard at inra.fr> alain.benard at inra.fr
Unité SILVA
Tél. : +33 3 83 39 40 84
Route damance
54 280 Champenoux
<http://www.inra.fr> inra.fr
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210627/7df9f9c0/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210627/7df9f9c0/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210627/7df9f9c0/attachment-0001.png>
