[postgis-users] Help with ST_CLIP
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Fri Mar 12 10:42:47 PST 2021
Hi Simon,
A geography column in 4236 sounds strange. Check the coordinate values
of the cast polygon.
select st_astext(geog::geometry) from gbr_marine_park_boundary;
and see if they look like what you expect.
-Steve W
On 3/12/2021 1:37 AM, Simon SPDBA Greener wrote:
> "POSTGIS=""2.4.3 r16312"" PGSQL=""100"" GEOS=""3.6.2-CAPI-1.10.2
> 4d2925d6"" PROJ=""Rel. 4.9.3, 15 August 2016"" GDAL=""GDAL 2.2.3,
> released 2017/11/20"" LIBXML=""2.9.4"" LIBJSON=""0.12.1""
> LIBPROTOBUF=""1.2.1"" RASTER"
> I have a polygon that defines the boundary of the Great Barrier Reef.
> A) That boundary is stored as a vector geography column (4326) in a
> table.
> B) I have loaded a raster dataset of depths (4326) and checked its
> statistics.
> The data loaded correctly and I can see valid depth values.
> Now I want to clip the data in B with the polygon in A.
> (I can't use a raster function with a geography object so I cast it to
> geometry.)
> create table gbr100x100clip
> as
> select ST_Clip(g.rast, 1, m.geog::geometry, false) as rast
> from gbr_marine_park_boundary as m,
> gbr100x100 as g;
> This works but the value (depth) of the whole (slipped) rasters is NULL.
> I expected to see depth values but this returns null values.
> SELECT (stats).*
> FROM (SELECT ST_SummaryStats(rast, 1) As stats FROM gbr100x100clip)
> As foo
> order by max desc;
> Can anyone give me an idea of what I am doing wrong?
> regards
> Simon
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
