[postgis-users] Help with ST_CLIP
Simon G Greener
simon at spatialdbadvisor.com
Fri Mar 12 13:55:30 PST 2021
Stephen,
A type 4326 not 4236.
> select st_astext(geog::geometry) from gbr_marine_park_boundary;
The numbers look correct after the cast.
Even though the data is extensive should I consider transforming to a
projected SRID?
Geographic rasters are not supported right? This is the reason for the
cast to call the ST_Clip function.
regards
Simon
On 13/03/2021 5:42 am, Stephen Woodbridge wrote:
> Hi Simon,
> A geography column in 4236 sounds strange. Check the coordinate values
> of the cast polygon.
> and see if they look like what you expect.
> -Steve W
> On 3/12/2021 1:37 AM, Simon SPDBA Greener wrote:
>> "POSTGIS=""2.4.3 r16312"" PGSQL=""100"" GEOS=""3.6.2-CAPI-1.10.2
>> 4d2925d6"" PROJ=""Rel. 4.9.3, 15 August 2016"" GDAL=""GDAL 2.2.3,
>> released 2017/11/20"" LIBXML=""2.9.4"" LIBJSON=""0.12.1""
>> LIBPROTOBUF=""1.2.1"" RASTER"
>> I have a polygon that defines the boundary of the Great Barrier Reef.
>> A) That boundary is stored as a vector geography column (4326) in a
>> table.
>> B) I have loaded a raster dataset of depths (4326) and checked its
>> statistics.
>> The data loaded correctly and I can see valid depth values.
>> Now I want to clip the data in B with the polygon in A.
>> (I can't use a raster function with a geography object so I cast it
>> to geometry.)
>> create table gbr100x100clip
>> as
>> select ST_Clip(g.rast, 1, m.geog::geometry, false) as rast
>> from gbr_marine_park_boundary as m,
>> gbr100x100 as g;
>> This works but the value (depth) of the whole (slipped) rasters is NULL.
>> I expected to see depth values but this returns null values.
>> SELECT (stats).*
>> FROM (SELECT ST_SummaryStats(rast, 1) As stats FROM gbr100x100clip)
>> As foo
>> order by max desc;
>> Can anyone give me an idea of what I am doing wrong?
>> regards
>> Simon
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
