[postgis-users] Does ArcGIS 2.7 Pro work with PostgreSQL 13 / PostGIS 3.1
Regina Obe lr at pcorp.us
Mon May 17 12:05:02 PDT 2021
Has anyone tried running PostgreSQL 13 with PostGIS 3.1 and using ArcGIS Pro
2.7 for editing?
I gather from this that it is not supported?
https://desktop.arcgis.com/en/system-requirements/latest/database-requiremen
ts-postgresql.htm
I think for ST_Geometry type (ESRI's version) I would need to stick with
PostgreSQL 12 since they probably don't have PostgreSQL 13 binaries.
But I assume even for that case PostgreSQL 12 / PostGIS 3.1 should work fine
as it's not reliant on ESRI's libs.
Thanks,
Regina
