[postgis-users] Does ArcGIS 2.7 Pro work with PostgreSQL 13 / PostGIS 3.1
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Sat May 22 03:51:14 PDT 2021
ESRI has multiple issues in itself that are terrible to debug.
A client of ours fights a bug where it can't browse tables once you set
random_page_cost to the SSD values of 1.1 instead of 4. So I guess if we're
using a bit more index scan than usual there may be an unknown problem that
does not show itself with QGIS and GeoServer.
On Mon, May 17, 2021 at 10:05 PM Regina Obe <lr at pcorp.us> wrote:
> Has anyone tried running PostgreSQL 13 with PostGIS 3.1 and using ArcGIS
> Pro
> 2.7 for editing?
> I gather from this that it is not supported?
> https://desktop.arcgis.com/en/system-requirements/latest/database-requiremen
> ts-postgresql.htm
> <https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-postgresql.htm>
> I think for ST_Geometry type (ESRI's version) I would need to stick with
> PostgreSQL 12 since they probably don't have PostgreSQL 13 binaries.
> But I assume even for that case PostgreSQL 12 / PostGIS 3.1 should work
> fine
> as it's not reliant on ESRI's libs.
> Thanks,
> Regina
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
OSM BY Team - http://openstreetmap.by/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210522/6ce40d29/attachment.html>
