[postgis-users] Does ArcGIS 2.7 Pro work with PostgreSQL 13 / PostGIS 3.1
Alexandre Neto senhor.neto at gmail.com
Mon May 24 01:53:59 PDT 2021
I have this question for years... Never got a straight answer.
Is it possible to edit PostGIS tables/geometries using ArcGIS? (Without
converting into the proprietary geometry type)
If so, what license level is needed?
Thanks,
Alexandre Neto
A sábado, 22/05/2021, 12:29, Marco Boeringa <marco at boeringa.demon.nl>
escreveu:
> I doubt this browsing issue has anything to do with 'random_page_cost'...
> Why on earth would it? This is a PostgreSQL setting, to which the ESRI
> software is essentially completely oblivious.
> The ESRI software just sits on top of this PostgreSQL infrastructure, it
> essentially doesn't do anything different than QGIS does, just watch the
> SQL statements coming in in PgAdmin.
> I have been running ArcMap and latest ArcGIS Pro versions against up to
> PostgreSQL 13 / PostGIS 3.1 mostly fine using ArcGIS "Query Layers",
> including browsing data from the catalogs in ArcMap and Pro, with a
> postgresql config optimized for SSD (both run against SATA and NVMe raid),
> and an OpenStreetMap "planet" size database on an HPZ840 dual CPU (S2)
> workstation that I managed to recently acquire second hand from a
> refurbished hardware supplier.
> Yes, I have a few bug cases open at ESRI support, including one related to
> a very specific serious performance issue of one of the geoprocessing
> tools, but none of that related to 'random_page_cost'. Also, as soon as you
> start upgrading the technical challenges to OpenStreetMap "planet" size
> databases, ArcGIS certainly isn't the only software out there running into
> issues here and there, QGIS does too, as well as many other software
> packages. Handling > 500M record tables, just requires thought, whatever
> toolbox you happen to open...
> Marco
> Op 22-5-2021 om 12:51 schreef Darafei "Komяpa" Praliaskouski:
> ESRI has multiple issues in itself that are terrible to debug.
> A client of ours fights a bug where it can't browse tables once you set
> random_page_cost to the SSD values of 1.1 instead of 4. So I guess if we're
> using a bit more index scan than usual there may be an unknown problem that
> does not show itself with QGIS and GeoServer.
> On Mon, May 17, 2021 at 10:05 PM Regina Obe <lr at pcorp.us> wrote:
>> Has anyone tried running PostgreSQL 13 with PostGIS 3.1 and using ArcGIS
>> Pro
>> 2.7 for editing?
>> I gather from this that it is not supported?
>> https://desktop.arcgis.com/en/system-requirements/latest/database-requiremen
>> ts-postgresql.htm
>> <https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-postgresql.htm>
>> I think for ST_Geometry type (ESRI's version) I would need to stick with
>> PostgreSQL 12 since they probably don't have PostgreSQL 13 binaries.
>> But I assume even for that case PostgreSQL 12 / PostGIS 3.1 should work
>> fine
>> as it's not reliant on ESRI's libs.
>> Thanks,
>> Regina
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> OSM BY Team - http://openstreetmap.by/
> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210524/b939d113/attachment.html>
