[postgis-users] ST_Union on empty polygon loses SRID
Regina Obe
lr at pcorp.us
Sun Nov 28 09:26:48 PST 2021
All the upgrade scripts are the same. We just delete the pre-release scripts to reduce disk space.
To upgrade yours do the following
-- this changes all your installed versions to 3.1.0 so you have an upgrade path
UPDATE pg_catalog.pg_extension SET extversion = '3.1.0' WHERE extname IN('postgis', 'postgis_raster','postgis_sfcgal', 'postgis_topology', 'postgis_tiger_geocoder');
SELECT postgis_extensions_upgrade();
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
> Of Jonathan Schultz
> Sent: Sunday, November 28, 2021 7:50 AM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] ST_Union on empty polygon loses SRID
> This is actually in response to Regina Obe's email which I didn't receive but
> only saw on the list archives. Maybe there is another way of replying to her
> message but I don't know it.
> I have definitely upgraded my debian/unstable installation.
> > $ dpkg-query -W postgis
> > postgis 3.1.4+dfsg-3+b1
> but still I get the previously mentioned response to postgis_full_version()
> I had presumed that this was just due to debian and postgis maintaining
> different versioning systems. But is it possible that postgresql is for some
> reason not registering the upgrade to postgis?
> One possibly related problem I found was:
> > NOTICE: Updating extension postgis from 3.0.2 to 3.1.0alpha1
> > ERROR: extension "postgis" has no update path from version "3.0.2" to
> version "3.1.0alpha1"
> > CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO
> "3.1.0alpha1";"
> > PL/pgSQL function postgis_extensions_upgrade() line 68 at EXECUTE
> Any suggestions?
> Thanks!
> On 27/11/21 15:18, Darafei "Kom?pa" Praliaskouski wrote:
> > Does not reproduce on my 3.2 and 3.1.4 installs:
> > 10:17:37[gis] > select postgis_full_version();
> > POSTGIS="3.2.0dev 3.2.0beta1-23-g94d4588ac" [EXTENSION]
> PGSQL="140"
> > GEOS="3.10.0dev-CAPI-1.15.0" SFCGAL="1.3.8" PROJ="7.2.1" GDAL="GDAL
> > 3.2.2, released 2021/03/05" LIBXML="2.9.12" LIBJSON="0.15"
> > LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
> > (1 row)
> > Time: 47,743 ms
> > 10:17:43[gis] > select ST_SRID(ST_Union(ST_GeomFromText('POLYGON
> > EMPTY', 4283)));
> > st_srid
> > 4283
> > (1 row)
> > Time: 1,531 ms
> > On Sat, Nov 27, 2021 at 7:34 AM Jonathan Schultz <jonathan at schultz.la
> > <mailto:jonathan at schultz.la>> wrote:
> > Hello,
> > I have found with a query that makes a union of geometries which
> > includes an empty polygon produces a result without an SRID. For a
> > trivial example:
> > > => select ST_SRID(ST_Union(ST_GeomFromText('POLYGON EMPTY',
> 4283)));
> > > st_srid ---------
> > > 0
> > This seems like a bug to me but maybe there is a good explanation?
> > Thanks,
> > Jonathan
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> > <https://lists.osgeo.org/mailman/listinfo/postgis-users>
