[postgis-users] ST_Union on empty polygon loses SRID
Regina Obe lr at pcorp.us
Sun Nov 28 09:47:57 PST 2021
Okay I didn't completely read the error:
> > > SELECT postgis_extensions_upgrade();
> > > NOTICE:  Updating extension postgis from 3.0.2 to 3.1.0alpha1
> > > ERROR:  extension "postgis" has no update path from version "3.0.2"
> > > to
> > version "3.1.0alpha1"
> > > CONTEXT:  SQL statement "ALTER EXTENSION postgis UPDATE TO
> > "3.1.0alpha1";"
> > > PL/pgSQL function postgis_extensions_upgrade() line 68 at EXECUTE
That error means your new version is 3.1.0alpha1 but you are scripts currently on 3.0.2.  So something is wrong with your binary install.  It could be you have a postgis installed for a different PG than what you are checking. PostGIS versions are tied to a specific PostgreSQL instance, and debian/ubuntu makes it easy to run multiple.
I would first check how many clusters you have and versions with below command:
pg_lsclusters
Mine for example shows:
Ver Cluster Port Status Owner    Data directory              Log file
13  main    5432 online postgres /var/lib/postgresql/13/main /var/log/postgresql/postgresql-13-main.log
Whatever you have active, you need to run something like the below replacing the 13 with whatever version of PostgreSQL you have active.
apt install postgresql-13-postgis-3
You shouldn't have to run the below steps I mentioned because your scripts are already on a released version postgis-3.0.2  but are bound to a in-development binary.  If you ran it already, it's still okay cause all the upgrade scripts are copies of each other.
> -----Original Message-----
> From: Regina Obe [mailto:lr at pcorp.us]
> Sent: Sunday, November 28, 2021 12:27 PM
> To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>;
> 'jonathan at schultz.la' <jonathan at schultz.la>
> Subject: RE: [postgis-users] ST_Union on empty polygon loses SRID
> All the upgrade scripts are the same. We just delete the pre-release scripts to
> reduce disk space.
> To upgrade yours do the following
> -- this changes all your installed versions to 3.1.0 so you have an upgrade path
> UPDATE pg_catalog.pg_extension SET extversion = '3.1.0' WHERE extname
> IN('postgis', 'postgis_raster','postgis_sfcgal', 'postgis_topology',
> 'postgis_tiger_geocoder');
> > From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> > Behalf Of Jonathan Schultz
> > Sent: Sunday, November 28, 2021 7:50 AM
> > To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> > Subject: Re: [postgis-users] ST_Union on empty polygon loses SRID
> > This is actually in response to Regina Obe's email which I didn't
> > receive but only saw on the list archives. Maybe there is another way
> > of replying to her message but I don't know it.
> > I have definitely upgraded my debian/unstable installation.
> >  > $ dpkg-query -W postgis
> >  > postgis 3.1.4+dfsg-3+b1
> > but still I get the previously mentioned response to
> > postgis_full_version()
> > I had presumed that this was just due to debian and postgis
> > maintaining different versioning systems. But is it possible that
> > postgresql is for some reason not registering the upgrade to postgis?
> > One possibly related problem I found was:
> > > to
> > "3.1.0alpha1";"
> > Any suggestions?
> > Thanks!
> > On 27/11/21 15:18, Darafei "Kom?pa" Praliaskouski wrote:
> > > Does not reproduce on my 3.2 and 3.1.4 installs:
> > > 10:17:37[gis] > select postgis_full_version();
> > >   POSTGIS="3.2.0dev 3.2.0beta1-23-g94d4588ac" [EXTENSION]
> > PGSQL="140"
> > > GEOS="3.10.0dev-CAPI-1.15.0" SFCGAL="1.3.8" PROJ="7.2.1"
> GDAL="GDAL
> > > 3.2.2, released 2021/03/05" LIBXML="2.9.12" LIBJSON="0.15"
> > > LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
> > > (1 row)
> > > Time: 47,743 ms
> > > 10:17:43[gis] > select ST_SRID(ST_Union(ST_GeomFromText('POLYGON
> > > EMPTY', 4283)));
> > >   st_srid
> > >      4283
> > > (1 row)
> > > Time: 1,531 ms
> > > On Sat, Nov 27, 2021 at 7:34 AM Jonathan Schultz
> > > <jonathan at schultz.la <mailto:jonathan at schultz.la>> wrote:
> > >     Hello,
> > >     I have found with a query that makes a union of geometries which
> > >     includes an empty polygon produces a result without an SRID. For a
> > >     trivial example:
> > >       > => select ST_SRID(ST_Union(ST_GeomFromText('POLYGON EMPTY',
> > 4283)));
> > >       >  st_srid ---------
> > >       >        0
> > >     This seems like a bug to me but maybe there is a good explanation?
> > >     Thanks,
> > >     Jonathan
> > >     _______________________________________________
> > >     postgis-users mailing list
> > >     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> > >     https://lists.osgeo.org/mailman/listinfo/postgis-users
> > >     <https://lists.osgeo.org/mailman/listinfo/postgis-users>
