[postgis-users] CentOS : postgis compatibility with postgresql.
postgo at khiplus.fr postgo at khiplus.fr
Wed Sep 8 00:16:05 PDT 2021
Yes thx i can install all theses postgis versions.
Sorry my question was not clear.
But postgis dependencies install the postgresql 11.13 version by
default, my question is more to know if (and how) i can choose a
specific postgresql version : ex : postgresql11-11.2-1PGDG.rhel7.x86_64
I don't know how to do that in centos...
Regards,
Le 07.09.2021 18:49, Regina Obe a écrit :
> Yes.
> It looks like for PG 11 you can do 2.5, 3, or 3.1
> https://download.postgresql.org/pub/repos/yum/11/redhat/rhel-7-x86_64/
> So try the below to get 3.0 for 11
> yum install postgis30_11
> To get 3.1 for 11
> yum install postgis31_11
> For 9.6 I've done:
> install postgis24_96
> for example -- so the version of PostgreSQL is always at the end and
> the number after PostGIS corresponds to the PostGIS minor version.
> Only caution is I think each might have different dependencies and
> PostGIS 3.1 may overwrite PostGIS 3.0 since we stripped the minor
> version in lib by default.
> Hope that helps,
> Regina
>> -----Original Message-----
>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>> Behalf Of postgo at khiplus.fr
>> Sent: Tuesday, September 7, 2021 11:56 AM
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> Subject: Re: [postgis-users] CentOS : postgis compatibility with
>> postgresql.
>> Thanks, it pass.
>> An other question but it is possible to choose the postgresql version
>> to install
>> with postgis ?
>> Regards
>> Le 07.09.2021 16:01, Regina Obe a  crit :
>> > Those dependencies I believe are included in
>> > https://download.postgresql.org/pub/repos/yum/common/redhat/rhel-7-
>> x86
>> > _64
>> > as noted in this thread
>> > https://lists.osgeo.org/pipermail/postgis-devel/2021-August/029136.htm
>> > l
>> > So you need to add that as well.
>> >> Sent: Tuesday, September 7, 2021 9:30 AM
>> >> To: postgis-users at lists.osgeo.org
>> >> Subject: [postgis-users] CentOS : postgis compatibility with
>> >> postgresql.
>> >> Hi,
>> >> For some tests, i am searching a way to install postgis with a
>> >> postgresql
>> > 11 on
>> >> an old centos (7.5).
>> >> Is there some list about compatibility of postgis and postgresql 11 ?
>> >> i
>> > can see
>> >> that :
>> >> https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
>> >> I found it on the 7.5 :  postgresql-9.2.23/24 (no postgis available)
>> >> But i
>> > need
>> >> to upgrade in a 11's version.
>> >> Then i made a new repository with postgresql 11 :
>> >> https://download.postgresql.org/pub/repos/yum/11/redhat/rhel-7.5-
>> >> x86_64/
>> >> To install by example postgresql11 (11.13) isn't a problem, but when
>> >> i
>> > want
>> >> to install postgis 2.5 there's dependency's problems :
>> >> # yum install postgis25_11.x86_64
>> >> Loaded plugins: fastestmirror, ovl
>> >> Loading mirror speeds from cached hostfile
>> >>   * base: centos-mirror.usessionbuddy.com
>> >>   * extras: centos-mirror.usessionbuddy.com
>> >>   * updates: centos-mirror.usessionbuddy.com Resolving Dependencies
>> >> --> Running transaction check
>> >> ---> Package postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
>> >> --> Processing Dependency: proj72 >= 7.2.1 for package:
>> >> postgis25_11-2.5.5-5.rhel7.x86_64
>> >> --> Processing Dependency: geos39 >= 3.9.1 for package:
>> >> --> Processing Dependency: gdal32-libs >= 3.2.3 for package:
>> >> --> Processing Dependency: xerces-c for package:
>> >> --> Processing Dependency: postgresql11-contrib for package:
>> >> --> Processing Dependency: postgresql11 for package:
>> >> libprotobuf-c.so.1(LIBPROTOBUF_C_1.0.0)(64bit) for package:
>> >> --> Processing Dependency: json-c for package:
>> >> --> Processing Dependency: hdf5 for package:
>> >> --> Processing Dependency: SFCGAL for package:
>> >> --> Processing Dependency: libtiff.so.5()(64bit) for package:
>> >> --> Processing Dependency: libprotobuf-c.so.1()(64bit) for package:
>> >> --> Processing Dependency: libproj.so.19()(64bit) for package:
>> >> --> Processing Dependency: libjson-c.so.2()(64bit) for package:
>> >> --> Processing Dependency: libgeos_c.so.1()(64bit) for package:
>> >> --> Processing Dependency: libgdal.so.28()(64bit) for package:
>> >> --> Processing Dependency: libSFCGAL.so.1()(64bit) for package:
>> >> ---> Package json-c.x86_64 0:0.11-4.el7_0 will be installed Package
>> >> ---> libtiff.x86_64 0:4.0.3-35.el7 will be installed
>> >> --> Processing Dependency: libjpeg.so.62(LIBJPEG_6.2)(64bit) for
>> >> package: libtiff-4.0.3-35.el7.x86_64
>> >> --> Processing Dependency: libjpeg.so.62()(64bit) for package:
>> >> --> Processing Dependency: libjbig.so.2.0()(64bit) for package:
>> >> ---> Package postgresql11.x86_64 0:11.13-1PGDG.rhel7 will be
>> >> ---> installed
>> >> --> Processing Dependency: postgresql11-libs(x86-64) =
>> >> 11.13-1PGDG.rhel7
>> >> for package: postgresql11-11.13-1PGDG.rhel7.x86_64
>> >> --> Processing Dependency: systemd-sysv for package:
>> >> --> Processing Dependency: libicu for package:
>> >> --> Processing Dependency: libpq.so.5()(64bit) for package:
>> >> ---> Package postgresql11-contrib.x86_64 0:11.13-1PGDG.rhel7 will be
>> >> installed
>> >> --> Processing Dependency: postgresql11-server(x86-64) =
>> >> 11.13-1PGDG.rhel7 for package:
>> >> postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
>> >> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.22)(64bit) for
>> >> package: postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
>> >> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.18)(64bit) for
>> >> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.11)(64bit) for
>> >> --> Processing Dependency: libxslt.so.1()(64bit) for package:
>> >> ---> Package protobuf-c.x86_64 0:1.0.2-3.el7 will be installed
>> >> ---> Package
>> >> ---> xerces-c.x86_64 0:3.1.1-10.el7_7 will be installed
>> >> ---> Package jbigkit-libs.x86_64 0:2.0-11.el7 will be installed
>> >> Package
>> >> ---> libicu.x86_64 0:50.2-4.el7_7 will be installed Package
>> >> ---> libjpeg-turbo.x86_64 0:1.2.90-8.el7 will be installed Package
>> >> ---> libxslt.x86_64 0:1.1.28-6.el7 will be installed Package
>> >> ---> postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
>> >> ---> Package postgresql11-libs.x86_64 0:11.13-1PGDG.rhel7 will be
>> >> installed
>> >> ---> Package postgresql11-server.x86_64 0:11.13-1PGDG.rhel7 will be
>> >> installed
>> >> ---> Package systemd-sysv.x86_64 0:219-78.el7_9.3 will be installed
>> >> --> Processing Dependency: systemd = 219-78.el7_9.3 for package:
>> >> systemd-sysv-219-78.el7_9.3.x86_64
>> >> ---> Package systemd.x86_64 0:219-57.el7 will be updated Package
>> >> ---> systemd.x86_64 0:219-78.el7_9.3 will be an update
>> >> --> Processing Dependency: systemd-libs = 219-78.el7_9.3 for package:
>> >> systemd-219-78.el7_9.3.x86_64
>> >> --> Processing Dependency: libcryptsetup.so.12(CRYPTSETUP_2.0)(64bit)
>> >> for package: systemd-219-78.el7_9.3.x86_64
>> >> --> Processing Dependency: libcryptsetup.so.12()(64bit) for package:
>> >> ---> Package cryptsetup-libs.x86_64 0:1.7.4-4.el7 will be updated
>> >> ---> Package cryptsetup-libs.x86_64 0:2.0.3-6.el7 will be an update
>> >> ---> Package systemd-libs.x86_64 0:219-57.el7 will be updated Package
>> >> ---> systemd-libs.x86_64 0:219-78.el7_9.3 will be an update
>> >> --> Finished Dependency Resolution
>> >> Error: Package: postgis25_11-2.5.5-5.rhel7.x86_64 (postgresql)
>> >>             Requires: hdf5
>> >>             Requires: libproj.so.19()(64bit)
>> >>             Requires: libSFCGAL.so.1()(64bit)
>> >>             Requires: gdal32-libs >= 3.2.3
>> >>             Requires: libgeos_c.so.1()(64bit)
>> >>             Requires: SFCGAL
>> >>             Requires: geos39 >= 3.9.1
>> >>             Requires: proj72 >= 7.2.1
>> >>             Requires: libgdal.so.28()(64bit)
>> >>   You could try using --skip-broken to work around the problem
>> >>   You could try running: rpm -Va --nofiles --nodigest
>> >> Do you know a solution to install postgis with postgresql 11 ?
>> >> Is it necessary to install with sources (./configure; make; make
>> >> install
>> >> Best regards,
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> https://lists.osgeo.org/mailman/listinfo/postgis-users
