[postgis-users] CentOS : postgis compatibility with postgresql.
Regina Obe
lr at pcorp.us
Tue Sep 7 09:49:51 PDT 2021
Yes.
It looks like for PG 11 you can do 2.5, 3, or 3.1
https://download.postgresql.org/pub/repos/yum/11/redhat/rhel-7-x86_64/
So try the below to get 3.0 for 11
yum install postgis30_11
To get 3.1 for 11
yum install postgis31_11
For 9.6 I've done:
install postgis24_96
for example -- so the version of PostgreSQL is always at the end and the number after PostGIS corresponds to the PostGIS minor version.
Only caution is I think each might have different dependencies and PostGIS 3.1 may overwrite PostGIS 3.0 since we stripped the minor version in lib by default.
Hope that helps,
Regina
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf Of postgo at khiplus.fr
> Sent: Tuesday, September 7, 2021 11:56 AM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] CentOS : postgis compatibility with postgresql.
> Thanks, it pass.
> An other question but it is possible to choose the postgresql version to install
> with postgis ?
> Regards
> Le 07.09.2021 16:01, Regina Obe a crit :
> > Those dependencies I believe are included in
> > https://download.postgresql.org/pub/repos/yum/common/redhat/rhel-7-
> x86
> > _64
> > as noted in this thread
> > https://lists.osgeo.org/pipermail/postgis-devel/2021-August/029136.htm
> > l
> > So you need to add that as well.
> >> Sent: Tuesday, September 7, 2021 9:30 AM
> >> To: postgis-users at lists.osgeo.org
> >> Subject: [postgis-users] CentOS : postgis compatibility with
> >> postgresql.
> >> Hi,
> >> For some tests, i am searching a way to install postgis with a
> >> postgresql
> > 11 on
> >> an old centos (7.5).
> >> Is there some list about compatibility of postgis and postgresql 11 ?
> >> i
> > can see
> >> that :
> >> https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
> >> I found it on the 7.5 : postgresql-9.2.23/24 (no postgis available)
> >> But i
> > need
> >> to upgrade in a 11's version.
> >> Then i made a new repository with postgresql 11 :
> >> https://download.postgresql.org/pub/repos/yum/11/redhat/rhel-7.5-
> >> x86_64/
> >> To install by example postgresql11 (11.13) isn't a problem, but when
> >> i
> > want
> >> to install postgis 2.5 there's dependency's problems :
> >> # yum install postgis25_11.x86_64
> >> Loaded plugins: fastestmirror, ovl
> >> Loading mirror speeds from cached hostfile
> >> * base: centos-mirror.usessionbuddy.com
> >> * extras: centos-mirror.usessionbuddy.com
> >> * updates: centos-mirror.usessionbuddy.com Resolving Dependencies
> >> --> Running transaction check
> >> ---> Package postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
> >> --> Processing Dependency: proj72 >= 7.2.1 for package:
> >> postgis25_11-2.5.5-5.rhel7.x86_64
> >> --> Processing Dependency: geos39 >= 3.9.1 for package:
> >> --> Processing Dependency: gdal32-libs >= 3.2.3 for package:
> >> --> Processing Dependency: xerces-c for package:
> >> --> Processing Dependency: postgresql11-contrib for package:
> >> --> Processing Dependency: postgresql11 for package:
> >> libprotobuf-c.so.1(LIBPROTOBUF_C_1.0.0)(64bit) for package:
> >> --> Processing Dependency: json-c for package:
> >> --> Processing Dependency: hdf5 for package:
> >> --> Processing Dependency: SFCGAL for package:
> >> --> Processing Dependency: libtiff.so.5()(64bit) for package:
> >> --> Processing Dependency: libprotobuf-c.so.1()(64bit) for package:
> >> --> Processing Dependency: libproj.so.19()(64bit) for package:
> >> --> Processing Dependency: libjson-c.so.2()(64bit) for package:
> >> --> Processing Dependency: libgeos_c.so.1()(64bit) for package:
> >> --> Processing Dependency: libgdal.so.28()(64bit) for package:
> >> --> Processing Dependency: libSFCGAL.so.1()(64bit) for package:
> >> ---> Package json-c.x86_64 0:0.11-4.el7_0 will be installed Package
> >> ---> libtiff.x86_64 0:4.0.3-35.el7 will be installed
> >> --> Processing Dependency: libjpeg.so.62(LIBJPEG_6.2)(64bit) for
> >> package: libtiff-4.0.3-35.el7.x86_64
> >> --> Processing Dependency: libjpeg.so.62()(64bit) for package:
> >> --> Processing Dependency: libjbig.so.2.0()(64bit) for package:
> >> ---> Package postgresql11.x86_64 0:11.13-1PGDG.rhel7 will be
> >> ---> installed
> >> --> Processing Dependency: postgresql11-libs(x86-64) =
> >> 11.13-1PGDG.rhel7
> >> for package: postgresql11-11.13-1PGDG.rhel7.x86_64
> >> --> Processing Dependency: systemd-sysv for package:
> >> --> Processing Dependency: libicu for package:
> >> --> Processing Dependency: libpq.so.5()(64bit) for package:
> >> ---> Package postgresql11-contrib.x86_64 0:11.13-1PGDG.rhel7 will be
> >> installed
> >> --> Processing Dependency: postgresql11-server(x86-64) =
> >> 11.13-1PGDG.rhel7 for package:
> >> postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
> >> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.22)(64bit) for
> >> package: postgresql11-contrib-11.13-1PGDG.rhel7.x86_64
> >> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.18)(64bit) for
> >> --> Processing Dependency: libxslt.so.1(LIBXML2_1.0.11)(64bit) for
> >> --> Processing Dependency: libxslt.so.1()(64bit) for package:
> >> ---> Package protobuf-c.x86_64 0:1.0.2-3.el7 will be installed
> >> ---> Package
> >> ---> xerces-c.x86_64 0:3.1.1-10.el7_7 will be installed
> >> ---> Package jbigkit-libs.x86_64 0:2.0-11.el7 will be installed
> >> Package
> >> ---> libicu.x86_64 0:50.2-4.el7_7 will be installed Package
> >> ---> libjpeg-turbo.x86_64 0:1.2.90-8.el7 will be installed Package
> >> ---> libxslt.x86_64 0:1.1.28-6.el7 will be installed Package
> >> ---> postgis25_11.x86_64 0:2.5.5-5.rhel7 will be installed
> >> ---> Package postgresql11-libs.x86_64 0:11.13-1PGDG.rhel7 will be
> >> installed
> >> ---> Package postgresql11-server.x86_64 0:11.13-1PGDG.rhel7 will be
> >> installed
> >> ---> Package systemd-sysv.x86_64 0:219-78.el7_9.3 will be installed
> >> --> Processing Dependency: systemd = 219-78.el7_9.3 for package:
> >> systemd-sysv-219-78.el7_9.3.x86_64
> >> ---> Package systemd.x86_64 0:219-57.el7 will be updated Package
> >> ---> systemd.x86_64 0:219-78.el7_9.3 will be an update
> >> --> Processing Dependency: systemd-libs = 219-78.el7_9.3 for package:
> >> systemd-219-78.el7_9.3.x86_64
> >> --> Processing Dependency: libcryptsetup.so.12(CRYPTSETUP_2.0)(64bit)
> >> for package: systemd-219-78.el7_9.3.x86_64
> >> --> Processing Dependency: libcryptsetup.so.12()(64bit) for package:
> >> ---> Package cryptsetup-libs.x86_64 0:1.7.4-4.el7 will be updated
> >> ---> Package cryptsetup-libs.x86_64 0:2.0.3-6.el7 will be an update
> >> ---> Package systemd-libs.x86_64 0:219-57.el7 will be updated Package
> >> ---> systemd-libs.x86_64 0:219-78.el7_9.3 will be an update
> >> --> Finished Dependency Resolution
> >> Error: Package: postgis25_11-2.5.5-5.rhel7.x86_64 (postgresql)
> >> Requires: hdf5
> >> Requires: libproj.so.19()(64bit)
> >> Requires: libSFCGAL.so.1()(64bit)
> >> Requires: gdal32-libs >= 3.2.3
> >> Requires: libgeos_c.so.1()(64bit)
> >> Requires: SFCGAL
> >> Requires: geos39 >= 3.9.1
> >> Requires: proj72 >= 7.2.1
> >> Requires: libgdal.so.28()(64bit)
> >> You could try using --skip-broken to work around the problem
> >> You could try running: rpm -Va --nofiles --nodigest
> >> Do you know a solution to install postgis with postgresql 11 ?
> >> Is it necessary to install with sources (./configure; make; make
> >> install
> >> Best regards,
> >> _______________________________________________
> >> postgis-users mailing list
> >> https://lists.osgeo.org/mailman/listinfo/postgis-users
